Old 04-17-2009, 08:35 PM
SierraK1500's Avatar
SierraK1500 SierraK1500 is offline
Exclamation 2005 Grand AM no start condition
My better half had to have her car towed this morning. Went to the store , shut the car off and when returned the ignition lights came on, and the security light is flashing on the dash. The car will not start. No starter, seems the ignition resets when the key is released. Also the door locks failed to operate. Is this a passlock problem? All other functions of the car are good.
Where do I start and can the passlock security be bypassed to get it running?
Thanks for your input....
John
SieraaK1500
Old 04-17-2009, 08:51 PM
Re: 2005 Grand AM no start condition
I forgot to mention that the check engine light is on too.
Old 04-18-2009, 02:32 AM
3100 3100 is offline
Banned
so no signs of cranking at all? how old is the battery? Check your battery voltage.
check engine light is probably not on, what you see is the bulb test for 3 sec.
Old 04-18-2009, 06:00 AM
Arrow Re: 2005 Grand AM no start condition
Battery is fine. AFTER the self test the security light is flashing and the check engine light burns steady. The ignition goes off when the key goes to start.
Old 04-18-2009, 02:47 PM
Banned
try relearn procedure
1.attempt to start the engine
2. leave the key in the run position for 12min
3. after 12min theft light should stop flashing
4. start the engine
Old 04-18-2009, 03:03 PM
Thumbs up Re: 2005 Grand AM no start condition
I tried the steps below and the car started up.
The key however muist be turned off and REMOVED. Then the car will start.
Pesky little BCM. Thanks for your help!
John
4. start the engine
Old 04-18-2009, 03:22 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
If it does it again, do the steps X3 before actualy starting it.
Oh and I wouldnt realy blame it on the BCM. Its more likly your ignition switch is goin out.
1999 Grand Am SS 3.4 OHV
Old 04-18-2009, 03:43 PM
Thank you all:
I have the correct proceedures:
Try to start the car.
Leave the ignition switch on for 12 to 15 mins.
Look to see if the Security light is out in the message center.
You should see the battery light on in the message center.
Turn the ignition OFF and REMOVE THE KEY.
Put the key in the Ignition and start the car.
John
