Old 04-17-2009, 05:14 PM
quackmandude quackmandude is offline
i really need yalls help
ok last week my belt snapped and it got locked up in my timing belt. so i went ahead and changed the belt, water pump and oil pump. i lined up everything but when i try to start it it, well doesnt. it sounds like it doesnt have compression. the cam gears r linedup right, and im pretty sure the crank is to..but if yall could find me a detailed picture of the markes i needa line up to on the crank, id appreciate it alot. also. could i have bent a valve??? my dad says i could have when the belt locked up. any help would be appreciated, thanks guys
SAMSUNG-SGH-I617/1.0 Mozilla/4.0 (compatible; MSIE 6.0; Windows CE; IEMobile 7.6)
Old 04-17-2009, 05:26 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: i really need yalls help
It sounds you like you dont have compression because you probably dont. Snapped timing belt 99% of the time = bent valves. Most likely all 12 intake valves are bent.
Old 04-17-2009, 05:30 PM
thats the thing, the timing belt never snapped. my power steering belt snapped and got hung up in my timing belt, and the engine locked. would that still bend the valves. i changed the timing belt just cause btw
Old 04-17-2009, 05:33 PM
Stealthee's Avatar
Yep. Same thing happened to a friend of mine. Power steering idler seized, caused the power steering belt to shred and it wrapped around the crank pulley and stopped his engine dead.
All 12 intake valves were toast.
Old 04-17-2009, 05:34 PM
so u think its a bent valve thenn???? ok well how much r stock valves???
Old 04-17-2009, 05:35 PM
Stealthee's Avatar
valves are cheap. its the work thats not cheap and not that easy.
Old 04-17-2009, 05:38 PM
i can do the work np, cheap like how cheap??
Old 04-18-2009, 10:24 AM
can i get the info on the mark that the crank hs to be when timing, id appriciate it
Old 04-18-2009, 08:02 PM
Stealthee's Avatar
There is a dot on the crank gear and an arrow thing on the oil pump. When you line it up you want to the dot 1 tooth counter clockwise (if I remember right) so when you pull the pin on the hydraulic tensioner than it pulls it one tooth up and all the marks line up.
Old 04-18-2009, 11:25 PM
yup....then i must have bent valves, well shit hahah
Old 04-19-2009, 11:10 AM
Stealthee's Avatar
Like I said, its almost a guarantee you did.
Pull it apart and go from there. It would probably be worth it to change the valve guide seals while you have it apart.
Old 04-20-2009, 10:40 AM
i changed those 50k miles ago, should i still change em?
Old 04-20-2009, 11:48 AM
Stealthee's Avatar
Well they are pretty cheap. It wouldnt hurt and you know they are new again.
Old 04-20-2009, 01:01 PM
man i just got off the phone with oreilys and for all 12 intake valves its 157 does that sound right?
Old 04-20-2009, 01:15 PM
ok i just lifted the cover and yup, all the intake rockers are off. with only means one thing...well my dad suggested that i go ahead and get my heads redone but thatll be a pretty penny....is it worth it???
