Old 04-16-2009, 10:37 PM
S10SNODOG's Avatar
S10SNODOG S10SNODOG is offline
Coolant leak from top of motor/intake
OK It's a 2003 s-10 vortec V-6 crew cab with 119,000 miles on it. On my way home from work I noticed a good dripping leak from under the engine, got home with a minimal amount of coolant loss and It did not go over 190 degrees or so well I further looked in to it and from under the truck it looks like its coming from the passanger side then looking from the pass. top of the truck right by the front intake manifold it's like ozzing from a bolt hole.First thought is the MANIFOLD GASKET if so how hard is it to do thank you very much Anthony
Old 04-17-2009, 08:03 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Coolant leak from top of motor/intake
First time it can take a day.
Make sure you get the felpro problem solver hard rubber gasket replacement.
There should be some how to down in the S-10 how to section.
Seting dist setup .
http://files.automotiveforums.com/ga...hp?photo=51302
First thing set dist as shown in picture.
Then start engine and read out camshaft retard setting with an engine capable scanner.
If your dist is turntable and not a locked solid type.
Set camshaft retard as close to 0 degrees - or + as you can get it.
Ever time you move dist you will need to speed engine over 1000 rpms for scanner to reset reading.
Has dist ever been replaced?
If the dist will not turn enough to set camshaft retard to 0.
You may have to remove dist and turn the dist gear 190 degrees to get the proper adjustment.
MT
Old 04-17-2009, 08:05 AM
MT-2500's Avatar
AF - Advisor
PS
Always change oil and filter and coolant with a intake gasket job.
Good Luck
MT
Old 04-20-2009, 11:43 AM
S10SNODOG's Avatar
Does any one have that FEL-PRO number for the intake manifold gasket I CANT SEEM TO FIND IT thank you so much guys Anthony
Old 04-20-2009, 02:57 PM
laxman21's Avatar
laxman21 laxman21 is offline
Fel-pro MS98002T
The one I used had metal instead of plastic in it.
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 04-20-2009, 03:04 PM
laxman21's Avatar
Fel-pro MS98002T
http://www2.partstrain.com/store/ind...94965186+11921
40 bucks!
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
