Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-16-2009, 07:11 PM
LeakSmoke LeakSmoke is offline
Send a message via AIM to LeakSmoke
Drive belt main component? locking mechanism?
Well, today when headed out to town, my drive belts failed me. one snapped and the other slipped off. i keep trying to look up info on the main component for the belt that has the locking mechanism so i can adjust the tension to it. but i cant come across an image/video of what the part/section looks like. im about to head back all the way out there in 2 hours so if i could just get pointed in the right direction it would really help me out big time. just so i can look at it for reference weather i can or cant fix it before the sun goes or not. i keep coming across the info that doesnt really give much to go on. so i beg you, if you can, pls give me a little info. i would really apretiate it. AAA only tows 7 miles and i cant afford or do a tow. so if i can get a good look at it an start today (maybe do it right tomorrow bright an early) for specs, its just a stock 1999 gs. thanks
Old 04-16-2009, 08:42 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Drive belt main component? locking mechanism?
There is a mechanical tensioner right above the AC compressor. You will see it when you looks down. Loosen the nut on the pulley that loose the screw that moves the pulley so you can slip the belt on. Not the alternator belt is a pain, have you to go under the car and loosen all the red nuts, you should be able to get to one from the top. And there is also a tensioner there. You will have to loosen that and slip the belt back on. It will suck doing it on the side of the road. Good luck though
Hope I got to you in time
http://images.google.com/imgres?imgu...%3D40%26um%3D1
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 04-17-2009, 10:01 AM
i didn't get to post it yesterday because i was in a rush. but thank you man! you saved my ass from leaving the car out there. i owe you it was a little hassle but managed to get it done
Old 04-17-2009, 10:06 AM
Holset powered 420a
Glad you got it fixed. It sucks when the car breaks down and you have to fix it on the spot.
98 Eclipse GS Turbo
2001 BMW 325i - DD
