Le Sabre Electrical problems
I have a 2005 Le Sabre and while driving, the tach, mileage, and dash lights flashed on and off. The speedometer, gas, and temperature needles are now cycling on and off (you can hear a scraping sound as this occurs) for a couple of minutes after starting... then work properly.
Any suggestions? |
Re: Le Sabre Electrical problems
Check this link, this may be your problem. http://arrc.epnet.com.oh0049.oplin.o...sp/framerq.asp
Can you give more explicit info about which base and where to see what you're wanting to show? Your location shows New York, so I wonder how you ended up on an Ohio user library database? |
Long story on my access to the Oplin set up, anyway it refers to erratic gage readings and noises from the gages and involves replacing the inst cluster. All the grounds in that circuit should be checked first, though.
