Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 04-15-2009, 02:00 AM
Caribe Caribe is offline
TPS losing 5v reference.
We have a 2000 Pontiac Montana that has an intermittent TPS. We changed out the TPS but we are still having problems. It looks like the TPS is losing it's 5 volt reference once in a while and reading 0 on the scanner. Press the pedal down and it would still read 0. When I read the codes it had p0122 TPS/Pedal position sensor A circuit low input( which was expected) and a p0452 Evaporative Emission Control System Pressure Sensor Low Input indicates a low voltage problem in the Fuel Tank Pressure Sensor (FTPS). I understand that also uses a 5 volt reference. Anyone know if changing the FTPS would be the next step. Is it located on top of the fuel tank over the fuel pump. Thanks
Old 04-15-2009, 03:03 AM
spike88 spike88 is offline
Banned
Re: TPS losing 5v reference.
For your TPS (throttle position sensor) trouble-shooting, here's some URLs that might help:
If replacing TPS: https://www.dsmparts.com/customer/pr...=27&page=&js=y
Troubleshooting: http://www.j-body.org/forums/read.ph...=49581&t=49581
Simular problem & solution on different GM vehicle:
- http://www.automotiveforums.com/t940..._from_pcm.html
Hope this info helps - somehow...
