Old 04-14-2009, 08:17 AM
Jim Ramstad Jim Ramstad is offline
intake manifold on 2000 grand prix 3800 engine exploding
Girlfriends car. Would not start after running great for two weeks following a replacement of the Mass Air Flow sensor and the crank sensor. Car did start for just a few seconds then nothing. Dealership took car in and the next morning they went to start it, it blew the plastic intake manifold into 4 or 5 parts and caught on fire. Just wondering if anyone has ever heard of this or has experiece with this happening. My fathers 2001 Buick Park avenue had an explosion under the hood a while back and the car burned to the ground.
Old 04-14-2009, 10:29 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: intake manifold on 2000 grand prix 3800 engine exploding
Its backfiring and blowing the plastic UIM to pieces. You need to figure out why its backfiring then replace the UIM.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 04-14-2009, 02:31 PM
Well yeah! I was wondering if any others here on this board have ever experienced it before. Dont want the car back if they dont find out what caused it. As my fathers car proved that if you dont get to it quick it will go up in flames fast.
Old 04-15-2009, 06:22 PM
tblake's Avatar
In God We Trust
I dont know. Overfueling maybe? When was the last full tune up done?
Run a search on the forum. Another member had this issue a while back, I cant remember how it was resolved.
Old 04-15-2009, 06:27 PM
ctwright ctwright is offline
I saw a thread a few days back in the new posts section where the title said 3800 engines recalled, I read the thread and it said it was because of fire risks, I have the same engine in my regal.
Old 04-15-2009, 06:30 PM
Found it. http://www.automotiveforums.com/vbul...d.php?t=949817
Old 04-15-2009, 06:36 PM
Yes, read the link in that thread, you may be able to get it fixed for free since that happened, I doubt that it had anything to do with your problem though. But 97 to 03 Grand Prix with that engine are in the recall.
Old 04-15-2009, 07:22 PM
tblake's Avatar
In God We Trust
He should defenatly bring the car in for the repair work unless he has replaced the valve cover gaskets already (most of us have), but his problem is with backfiring and blowing up the upper intake manifold.
Jim, I think you should replace the UIM, get the car running, and then check out the fuel system. Make sure that the fuel pressure regulator isnt leaking gas into the UIM.
Was the SES light on? Any codes?
I wonder if there is some way the ignition timing is off....
Old 04-16-2009, 07:39 AM
The car is in the shop right now. In fact it was the dealership that tried to start it when it blew. I am just wondering if anyone here has seen or heard of this before because they claim at the dealership that they have never seen this before but our Mechanic who came from there said he has seen it a few times. They are having a hard time diagnosing it as has been a week since it happend and the $ is piling up!
Old 04-16-2009, 03:00 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I've never heard of one of these plastic UIM's exploding unless someone was spraying starting fluid or other flammable liquid into the UIM in an attempt to get the car to start. It's not uncommon for overzealous DIY people to do this, but a dealership should know better. There's an outside chance as Tblake mentioned that a leaky FPR allowed fuel to get in there, but highly unlikely. IMO, the dealership owes you a UIM as I believe their tech screwed up.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 04-16-2009, 03:14 PM
The problem I am having with this is my fathers car burned to the ground and his car sat for a month and when he hit the key he heard what sounded like a shotgun going off under the hood, then flames. The mechanic trying to start the pontiac was not using starting fluid as the day before when they picked it up the car had no spark. I have read several other forums that have said that GM was investigated on this and over 600 incidents and over 45 fires from this so I wanted to see on here. Really surprises me that no one has had this happen. Mechanic as lucky as if he would have been standing in front of the car he would have been badly hurt or killed!
Old 04-16-2009, 06:00 PM
http://www.carcomplaints.com/Buick/R...exploded.shtml
http://www.carcomplaints.com/Chevrol...exploded.shtml
http://www.carsurvey.org/viewcomments_review_44502.html
http://www.allworldauto.com/comments...1998-72-1.html
http://www.canadiandriver.com/forum/...ftopic=55704.0
Old 04-16-2009, 06:28 PM
I'm trying to find a specific recall for yours but I seen several vehicles I think the problem was the fuel pressure regulator which was recalled and was the cause of the problems with backfiring and the intake manifolds exploding.
Old 04-16-2009, 07:18 PM
tblake's Avatar
In God We Trust
Jim, are you sure the fire on your dad's car wasn't an effect of a leaky valve cover gasket? Was it the same 3800na motor as yours?
Old 04-16-2009, 07:23 PM
tblake's Avatar
In God We Trust
This reminds me of a cadillac (northstar) that came into the shop one day. I know, different motor, but attempting to start the car, it kept backfiring, and oh man, just a quick crank and BOOM! In the shop it sounded like a bomb went off. No one could figure out why untill someone noticed that one of the plug wires had been routed to the wrong plug.... Once on the right plug, car ran good.
