Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 04-13-2009, 09:06 PM
tccoupe tccoupe is offline
Tires
Now that the snow is nearly gone it's time to start thinking about this season. I've been running the pirelli p zeros d3 that came with the car. I bought a couple of extra sets when i got the car. Just looked at the price of new ones and wish i'd bought more. I've been happy with the pirells' but am curious what other people have been running. If you have any input i'd be interested to hear it. Mine is a series car with 18" wheels
thanks - bruce
Old 04-13-2009, 11:58 PM
Blue Streak 21's Avatar
Blue Streak 21 Blue Streak 21 is offline
Re: Tires
Hoosiers or Kuhmos depending on how long each race is for. Hoosiers Cup slicks for long or endurance races, and Kuhmos for sprint races.
Jerry
Jerry
1999 Panoz GT-RA
Old 04-14-2009, 12:39 AM
boothkc boothkc is offline
Re: Tires
Hoosier R6s would be my first choice providing you have the frame reinforcements to support slicks (near slicks) else street tires to reduce grip and stress. Kuhmo has some DOT legal near slicks as well, but we've had great luck and durability with the R6s. If you really want max grip then the new Hoosier Radial Slicks are the fastest tire we've tested, but driving on slicks leaves little room for error near the edge of grip.
Have fun,
Kevin
GTS/GTRA
SR22
Old 04-14-2009, 01:29 PM
eric1h eric1h is offline
Re: Tires
I have been VERY happy with the new Michelin racing slicks! mad grip!
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
Old 04-14-2009, 04:14 PM
GTS#25's Avatar
GTS#25 GTS#25 is offline
Re: Tires
Just tried a set of Michelin slicks and I am running my best lap times.
They are very reasonably priced as well.....
http://www.jdmotorsports.com/tiresales.aspx
Doug
Old 04-14-2009, 07:36 PM
panozracing's Avatar
panozracing panozracing is offline
Re: Tires
We have tried:
Hoosier R6
Hoosier Grand Am Slicks (felt bad but might need a diff. setup to work)
Yokahama Slicks (the worst)
Michelin Slicks
Pirellis Slicks
Dunlops (only ran 17" when it was the spec from Panoz back in the day)
The Michelins and the Pirellis are the best. We run the Pirellis because they are better, have choices in compounds, and supply chain has served us better. We had issues getting tires from JD Motorsports.
IT all depends on what you are doing. The slicks are going to be stickier but once they drop off they really drop off. The DOT legal tires will slowly fad but will never be as sticky and they cost less.
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 04-14-2009, 10:27 PM
coach0187 coach0187 is offline
Re: Tires
Just tested the new hoosier slick and it was 2 seconds faster than any other tire I've used.
Old 04-15-2009, 08:23 AM
Re: Tires
What other tires have you tried. 2sec is alot.
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 04-15-2009, 07:26 PM
Re: Tires
We've have tested pirellis, michelins, and yokahamas. We tried the hoosier grand am tire but it didn't work to well. I got the best results with my pro driver, the other guys were just alittle better. But they all said that the new hoosier felt alot better.
Old 06-16-2009, 04:05 PM
Jim woodruff's Avatar
Jim woodruff Jim woodruff is offline
Re: Tires
Tire size help needed- I am running the p-zero 285/645/18 tires on my Wc car.
dia. 25.79"
tread 11.02"
section 11.22"
I want to run the 28.0x12.5 R18
dia. 28.0"
tread 11.02 "
section 11.22 "
The difference is
Tread plus 1.73"
Dia. plus 2.36"
section plus 2.6 "
Has anyone used this size tire and do you think they will fit with out any problems fit and function. I am not concerned about the reduced turning radius.
Old 06-19-2009, 10:35 AM
Re: Tires
dia. 25.79"
tread 11.02"
section 11.22"
dia. 28.0"
tread 11.02 "
section 11.22 "
The difference is
Tread plus 1.73"
Dia. plus 2.36"
section plus 2.6 "
correction to the above dimensions:
The 28..0 X 12.5 R18
Dia. 28.15"
Tread 12.75 "
section 13.87
I need helpfull input for fit. Thanks Jim
Old 06-19-2009, 09:36 PM
NZGTRA17 NZGTRA17 is offline
Re: Tires
Dia. 28.15"
Tread 12.75 "
section 13.87
Jim, have you calculated the effect that the additional diameter will have on your gearing? Other thing to think about, is do you really want a tyre with so much side wall? If you could get the extra tread width without the increased diameter that would be more ideal, especially for the front tyres.
Kel.
Kel M
Panoz GTRA #17
New Zealand
Old 06-20-2009, 08:11 AM
Re: Tires
Kel.
yes and yes. Do you think they will fit under the car with out fender modifications.
Old 06-21-2009, 10:05 AM
Re: Tires
I tried one this morning and they will not fit. The Grand Am Pirelli people were nice enough to give me one to try.It goes back today. Boo Hoo
Old 06-24-2009, 11:31 AM
Racer9007 Racer9007 is offline
Send a message via Skype™ to Racer9007
Re: Tires
I run the Pirelli P zero slicks, with a 285 in the front (on a 10" rim)and a 305( on a 11 inch rim) in the rear. You can stuff a 305 in the front but you will have clearnce issues at steering lock, and have to trim the fender back. In the rear the 305 measure small, but the next size 325 is to big, and does not work as well on the cars handling, with out major set up changes (different construction). Also they are built t be on a 12" rim. I have ran the Michelins, but found them to be much slower on my set up, and they cost more. They due last a little longer, but were 2 seconds slower in our test, and dont warm up as fast.
Matt
