Old 04-13-2009, 01:57 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Fix your flasher module save bucks
I put this here because it appears more and more are having success fixing there turn sigs using this repair. Originally posted by catfishfryer (thanks again) in March 2008. This will make it easier for all to find:
An intermittent or occasional Dodge Chrysler 4686094 flasher module can be repaired easily! SAVE YOUR $45!!
1. Pull out the flasher;( it is 1"x1" x 2" #4686094 relay module under dash, put your head against the brake pedal and look up, it sticks up higher than most and is 3/4 way up on relay panel; if you push on the relay with the blinker on, and it may start clicking to help you identify it. My car is a 1996 dodge caravan ). The relay is a pain to get out, but keep thinking of the $45 you save.
2. Now to repair the relay. On the spade pin side of the relay, bend and brake off the two 1/2" x 1/32" plastic ears that hold the relay cover on and slide the relay cover off.
3. Look at the circuit board side with the shiney solder connections. The exterior pins go thru the plastic base and are soldered to the circuit board. These solder connections to the pins get hairline stress fractures and are intermittent as they make and lose contact. If you use a magnifier glass you can see the offending cracked solder joint.
4. Re-Solder each contact point on the circuit board edge. This can be done by just reheating the contact with a solder iron till the solder flows a little . If you do use some extra new solder, make sure it does not flow across (bridge) the contact points. It is not necessary to re-solder the component connections on the board.
5. Put cover back on and secure with a dot of glue or short piece of scotch tape , and reinstall in car (I cursed alot when having to blindly reinstall, it is more a pain than removal, but I kept thinking of the $45 saved).
Try this and keep from giving $45 dollars of hard earned money to the unworthy dealer.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
