Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 04-13-2009, 11:58 AM
IceWewe IceWewe is offline
Question Advice: 1994 SW2 Alternator, worth replacing?
Hello all,
I was driving down the highway the other day in my SW2, which was running perfectly, when I look down at the dash and notice, to my dismay, that the battery indicator light was on. Got out my multi-meter and measured the battery voltage when the car was on and off, and there's no change, it's flat at 12V (don't have a meter that measure to more digits then that on me.)
I'm wondering, since this car has a cracked windshield and the odo no longer works, is it even worth the money to fix this? What would you do in my position?
It seems like every other month (quickly becoming every month) it's something else with this car. Last November the spark plugs, wires, and the serp belt were replaced to fix a lack of acceleration. Last month I had the muffler replaced as the old one gave out.
Car has approximately 155 000 miles on it (I don't know exactly since the odo stopped worked several months ago,) where do I draw the line?
Thanks for your thoughts/suggestions.
Last edited by IceWewe; 04-13-2009 at 11:59 AM. Reason: Changed icon from sad face to question mark
Old 04-13-2009, 12:46 PM
CL8 CL8 is offline
Re: Advice: 1994 SW2 Alternator, worth replacing?
Originally Posted by IceWewe View Post
Hello all,
From my budget standpoint, if I couldn't afford the payment for a new or good used car, I would keep fixing it.
If my budget could afford the payments on a good used vehicle I would go that route.( preferably pay in cash for a good used vehicle with the money you would spend fixing you old one, then you would have no payments.)
Also make sure a mechanic checks out a vehicle you might buy, you would hate to buy a vehicle with worse problems than the one you have.
That if thou shalt confess with thy mouth the Lord Jesus,
and shalt believe in thine heart that God hath raised him from the dead,
thou shalt be saved.
For with the heart man believeth unto righteousness;
and with the mouth confession is made unto salvation.
Romans 10:9-10
Old 04-15-2009, 10:31 AM
RC1488 RC1488 is offline
You could rebuilt the car top to bottom and still pay less than that for a new car. Id fix it.
You can always go to the junk yard. Get a new (used really ) alternator. Here's how to change it:
http://www.youtube.com/watch?v=iogtiYraHCg
The windshield I recommend having it fixed by a professional. The 1st gen windows are tricky and unfortunetly more pricey than the rest of the s-series.
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
Old 04-15-2009, 03:14 PM
@RC1488
Thank you, having a visual on how this is done is really helpful! This, in addition to the repair documents I have on where the bolts are including sizes, etc, should make this an easy job.
Do you happen to have instructions on how to get the splash panel(s) off? That's the only part I can't figure out at this point.
Old 04-15-2009, 08:06 PM
@RC1488
They are held in with push pin type fasteners. Remove the center of the push pin then the outside. I believe there are 2 on each side. Then remove the slash guard
Old 04-20-2009, 02:11 PM
SC2ner SC2ner is offline
The car is certainly worth keeping. Not only are first Gen wagons rare (from a enthusiest pov) but you are replacing maintainance parts. Serp belt, plugs and wires??? You think a new car will not make you replace those. They go bad. It's what they do. Alternators for these cars are around 70-100 dollars. Go on Saturnfans.com and send a private message to OldNuc. He will tell you what the website is for cheap but good quality alternators. The windshield is really up to you. Through saturn, IIRC, is really exspensive. Trying contacting a comepany called safelite. Look them up on google. We use them for a dealer. They are all over and do a good job for cheap.
What RC said is right. Access the alternator by removing the splash shield on the passenger side. Disconnect the battery first. Then remove the serp belt and bolts and the battery harness and unplug it and you're good to go. Quick easy repair.
Why are you trying to act hard as hell,
when you know damn well
you don't wanna feel the shell
Old 04-25-2009, 06:08 AM
s1120 s1120 is offline
I would replace it..
Unless you are buying new, odds are any used car will need that stuff anyways.
