Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 04-12-2009, 03:13 PM
olds1995 olds1995 is offline
Charging A/C
1995 Olds Cutlass Supreme FWD.
I evacuated the system and it held vacumn for over an hour. I started adding freon, 134A, with a relatively new set of gauges.
Problem is the compressor clutch won't engage (I guess no pressure safety???). I recall back in the 60's-70's using a paperclip/jumper wire inserted someplace to get the old ones kick-started.
How do I get the '95 compressor clutch to engage?
Thanks, Marvin
Old 04-12-2009, 05:20 PM
brcidd's Avatar
brcidd brcidd is offline
Re: Charging A/C
Your variable compressor system does not have a cycling switch- because it does not cycle-- it destrokes inside the compressor to avert freeze-up. Compressor will come on by itself (when system pressure exceeds 47 psi) if all conditions are correct- the pressure is monitored by a pressure transducer (3- wire) on the high side liquid line- do not try to jumper this- will cause undue harm to your electronics..
One thing your car a/c system is known for- is the power steering pressure switch failure- due to corrosion, the switch may be broken off entirely-- it is normally open- so unplugging it may help-- look for it under driver's side on power steering high pressure hose behind front left wheel, under car..this switch is there in only a few years and only on W-cars - intent is to turn off a/c compressor when in tight parking maneuvers so as not to stall the engine...it was replaced in later years by the stall saver routine- that meerly shuts off a/c when engine rpms drop below 500...
I have unplugged about a dozen of those switches- be sure to tape it off- otherwise oil change machanics will plug them back in- and you won't have a/c again-- if this is what the original problem is..
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 04-12-2009, 06:35 PM
Re: Charging A/C
brcidd, Thanks, your A/C brilliance is only exceeded by your willingness to share. I didn't know about the 47# so I hooked up a new can and opend the valve and waited. When the low side reached 47# the compressor kicked on and I completed the charge. Thanks again.
Marvin
