Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 04-12-2009, 12:39 PM
aristat aristat is offline
exhaust smoke problems
I have a 1990 Olds 98 that was running great and just recently started smoking from exhaust. The smoke is white in color and the car around engine smells like gas. The engine wil run but is missing and the service engine light does not come on. Any advice for fixing would be appreciated?
Old 04-12-2009, 12:50 PM
ctwright ctwright is offline
Re: exhaust smoke problems
Problem is either too much fuel or too week ignition(that's what I think), you need to check over all of your ignition components. Timing could be off some as well.
Old 04-12-2009, 12:56 PM
It wil start and idle with the smoke and then I can turn it off and then it will not start again. After trying, I saw a lot of smoke under hood and when I open it, there were flames coming from under the manifold. I put it out and I am just wondering where to start.
Old 04-12-2009, 01:09 PM
You need to check your ignition timing. It not starting after that is probably flooding due to unburnt fuel.
Old 04-12-2009, 03:30 PM
Okay, thanks for the information. I will try this.
Old 04-12-2009, 03:57 PM
"Ninety-Eight 1990-1993
Ignition Timing Adjustment
Because the C 3 I system uses a crank sensor for est, ignition timing is not adjustable. However, positioning of the interrupter ring is very important. A clearance of 0.025 inch is required on either side of the interrupter ring."
I copied the above information from the autozone repair guide and according to this information, adjustments to the ignition timing, can't be made. Can you think of what could be causing the problems?.........Thanks Tom
Old 04-12-2009, 04:01 PM
Does your vehicle use a timing belt or timing chain? It may be possible it has jumped time if it uses a belt.
Old 04-12-2009, 04:10 PM
It has a timing chain.........
Old 04-12-2009, 04:20 PM
May not be the timing I was just thinking it might be. I would go all over the ignition components, wires, plugs, and check to see what the spark looks like as well.
Old 04-12-2009, 05:59 PM
I will check that out but I am still puzzled about the excess gas, the gas smell and the white smoke coming from the exhaust??
Old 04-12-2009, 06:24 PM
Not firing correctly can cause the excess gas, gas smell and white smoke, because not all the gas is getting ignited.
Old 04-12-2009, 06:34 PM
Makes sense, thanks for your information. One more question, would the "service engine light" come on if it wasn't firing correctly? It never came on except when the engine would stall or while turned off.....
Old 04-14-2009, 07:35 AM
Turned out to be fuel injector that was dumping fuel so much that it was dumping gas into the manifold.
Old 04-14-2009, 04:07 PM
Glad you got it fixed, I figured it was either too poor spark or too much fuel.
Old 04-14-2009, 10:47 PM
duke350 duke350 is offline
Be a good idea to change your oil now also.
