Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 04-11-2009, 09:08 PM
raymondzz raymondzz is offline
1995 neon runnung rough
Have 95 neon running rough, start easy but runs around 1500 and 1600 rpms up and down, any good place to start looking?
Old 04-12-2009, 10:55 AM
Oldsmobile Doctor Oldsmobile Doctor is offline
Re: 1995 neon runnung rough
Check for a vacuum leak or a hose off. Had that on a 2000 and it was the power brake hose off. Idled fast and didn't have power on the brakes the guy almost plowed someone.
Old 04-12-2009, 11:09 AM
ctwright ctwright is offline
Also check to make sure that your throttle cable isn't too tight.
Old 04-12-2009, 11:11 AM
A bad throttle position sensor can also cause too low or too high of an idle. This should set a code though and cause your check engine light to come on.
Old 04-12-2009, 07:17 PM
Thank, I will double check all hose. It runs 1500-1550 rpms up and down all time. Max rpm is only 4000 rpm before it act like it floods out.
Old 08-03-2009, 12:52 PM
tnbgaskill tnbgaskill is offline
Mine has similar problems did you ever figure it out?
Old 08-05-2009, 06:17 PM
It was the throttle position sensor. Car was hit in front end and push sensor forward so it look like it was still in place. Replaced it and runs great. Thanks for all help.
