Old 04-11-2009, 12:49 PM
dynastykid22 dynastykid22 is offline
Exclamation 2004 cavalier - Please Help
IAT sensor causes code PO 113 to come on the scanner, replaced the sensor and the code continues to come on, tranny feels like it is going to blow, tranny shifts super hard, also I cant even drive the car without the scanner in it to erase the code every time the light comes back on
please help .... driving me crazy
Old 04-11-2009, 03:37 PM
manicmechanix manicmechanix is offline
Re: 2004 cavalier - Please Help
What tempetature is the scanner reading for IAT when it is setting a fault? Jumper the connector terminals and it should read like over 260F.
Old 04-30-2009, 06:07 PM
sorry took so long the scanner does not read a temp, any thing else you would suggest
Old 04-30-2009, 06:47 PM
J-Ri's Avatar
J-Ri J-Ri is offline
You'll need something more advanced than a simple code reader to diagnose a problem like this. Even something like a scan gauge (scangauge.com) is better than what you have. I don't really care for it as a diagnostic tool, I only bought it for the extra gauges (but they're cheap). It has a limited datastream that will show about 1/16 of all the info available from the PCM, and can be programmed to read anything in the PCM (but isn't capable of any other modules). It comes programmed with ECT, IAT, RPM, TPS, vehicle speed, MAP, timing advance, and maybe a dozen other things that I've never had a use for using it only for the gauges.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
