Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-11-2009, 10:04 AM
kshook.2's Avatar
kshook.2 kshook.2 is offline
95 caprice programmer
is their any way to make a obd2 hypertech power programer work on a obd1 or i their no you can re wire it thanks
Old 04-11-2009, 10:55 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 95 caprice pro grammer
No, the two systems are totally different.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 04-11-2009, 10:58 AM
96capricemgr 96capricemgr is offline
The hypertech is crap anyway. You do not want it.
96 Caprice Medium Garnet Red
11.56 at 115.9mph naturally aspirated
94 Caprice wagon, rotted out POS
Old 04-11-2009, 11:12 AM
kshook.2's Avatar
thanks i was just wondering im in the process of changing motors from a 4.3 to the 5.7 lt1 i found some one that programs them for $75 dollars no matter what you whant he will program it for you
Old 04-11-2009, 11:15 AM
The Hypertech usually only modifies programming so you have to have the right base programming to start with and you won't if swapping engines like that.
pcmperformance.com can help you out.
My car originally came with the 4.3l too, if you have questions ask.
Old 04-11-2009, 11:21 AM
kshook.2's Avatar
i no the computers are same on the 4.3 as the 5.7 the computer just has to be erased re programmed i found some one that does that for $75 dollars no matter what you whant done to it web site is www.lt1swap.com/programming
