Go Back   Automotive Forums Car Chat > Buick > Rendezvous
Old 04-10-2009, 11:38 PM
cloner3 cloner3 is offline
heated seats don't work
My heated seats have worked perfectly even since I have had my 2003 Rendezvous. Tonight, I flipped the switch, and nothing happened. Likewise for the passenger seat. I couldn't find a fuse for this. Any suggestions or help would be greatly appreciated.
Old 04-13-2009, 01:24 AM
TopherS's Avatar
TopherS TopherS is offline
Re: heated seats don't work
Be sure to check the owners manual to find the fuse location for the heated seats. Many times, the fuse will protect more than one thing, so it could be listed second to another circuit also protected by that fuse... and there are often more than one fuse box (including under the hood) on the car. The owners manual will have a diagram for each fuse box and a list of which circuits each fuse protects (and the size of fuse required). Because both seats' heaters no longer work, they are most likely on the same fuse (I mention this because my Park Avenue has the right headlamp and the left headlamp on separate fuses, so it is conceiveable that the driver's seat and passenger seat heaters could be on separate fuses, as well...but it would appear not in this case...a thorough check of the fuse listing will tell you for sure).
I don't have my wife's owners manual handy at the moment...otherwise, I'd look to see. If you don't happen to have yours, lemme know.
Hope this helps.
Topher S
Portland, OR
2001 Buick Park Avenue
2006 Chrysler Town & Country Limited
