Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 04-10-2009, 05:22 PM
Grgshot Grgshot is offline
97 T-Bird, V-6 front end work
How hard is it to reblace the front wheel hub/bearing assembly. I have replaced about everything else in the fron suspension this and strut bearings and Im done for awhile. Any special tools besides a 2 jaw puller and hub socket?
"Give a man a fire and he will be warm for the day.
Set a man on fire and he will be warm for the rest of his Life!"
Old 04-11-2009, 10:27 AM
97Bird's Avatar
97Bird 97Bird is offline
Re: 97 T-Bird, V-6 front end work
Remove the caliper and hang it with a piece of wire. Remove the hub cap grease seal and then the hub retaining nut. Sometimes you don't even need a puller to remove the hub from the spindle. When replacing the hub remember to install a NEW hub retainer nut and torque to 188-254 lb-ft. Ford also recommends to replace the hub cap grease seal.
The Original 97Bird
Old 04-11-2009, 10:34 AM
AWESOME!!! Sounds like it will be the easiest fix on that frontend yet!!
( knock on wood). Thank you, I owe you a beer!
