Old 04-10-2009, 05:05 PM
chevyrulespops's Avatar
chevyrulespops chevyrulespops is offline
location of airbag components
Shortly after I drilled a couple of holes through the passenger side dash board where the camaro badge is typically located to install a map holder I got the Inflatable restraint light on all the time...Im thinking something air bag related might have been behind this...am I correct?
Old 04-11-2009, 07:42 AM
dugan50's Avatar
dugan50 dugan50 is offline
Authorized Vendor
Re: location of airbag components
You are correct. You drilled right through the passenger airbag module. You are incredibly lucky it didn't deploy while you were drilling or immediately upon turning on the key.
You've got some work and some expense ahead of you, but here's a site that will explain everything you need to know about airbag systems, airbag lights and resetting the system. It shows you the location of the components and the procedure for diagnosing and resetting airbag lights.
http://www.airbagsolutions.com/
You can check to see if your car is listed here.
http://www.airbagsolutions.com/vehicles_list.aspx
If the light is flashing on your car it's telling you there's a problem. On some vehicles, the light is flashing a two digit code. Once you know the code, you can most likely repair it yourself. There are fairly easy procedures that most people are capable of repairing.
Airbagsolutions.com has the fault code charts to tell you what is wrong and how to fix it!
Some vehicle manufacturers let you access and reset systems without a scanner (like Toyota, Lexus, Nissan, Infinity, Honda, Acura, Ford, Lincoln, Mazda & Mercury) and some require a scan tool.
Although it’s a pay site ($14.95/day), it’s a lot cheaper than going to the dealer
I hope this was helpful to you. My information comes from years of experience in these businesses.
http://www.airbagsolutions.com http://www.stolenandrecovered.com
Airbag Service, Airbag Replacement, Airbag Diagnostics
Thank You,
Douglas Gan
