Old 04-10-2009, 01:08 PM
Enthor Enthor is offline
Wiring Harness Issue
I have a 2002 GMC Jimmy SLS. I recently went out and bought a new deck for my truck, a Sony CDXGT430IP. I purchased a wiring harness as well for the deck, wired everything up and thought I was good to go. My only issue was my truck came with a factory 6 speaker system. The harness only had hookups for 4 speakers, as well as the deck. The guy at Futureshop said it would work in my truck, but it doesn't. Can I upgrade my system, or is my current setup as far as I can go?
Old 04-10-2009, 02:25 PM
Ovar Ovar is offline
Re: Wiring Harness Issue
So your saying that only 4 of the 6 speakers are working, or none of the speakers are working?
-Ryan-
1995 Buick Century Special 3.1L
1996 Ford Windstar 3.8L
1994 Buick Regal 3.8
Old 04-10-2009, 02:37 PM
None of the speakers work. I have power to the deck, but nothing through the speakers.
Old 04-10-2009, 03:04 PM
What I would do is return the wiring harness and get yourself a 9volt battery and a cheap volt meter.
First use the volt meter to identify your constant power,ignition power, and ground. Tape and mark these wires. Next use the 9volt battery to pop the speakers to identify FR,FL,RL,RR and whatever other speakers you have. Label these wires as well.
Lastly, before you take your wiring harness back use the diagram on the packaging to match up the appropriate wire from the deck to you vehicle.
The only other option is to buy a 6 channel amp and rewire you speakers.
-Ryan-
Old 04-10-2009, 03:51 PM
So what do I do once I figure out which speaker is which? My harness still only supports 4 speakers.
Old 04-10-2009, 07:38 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
speakers 5 & 6 are probably just tweeters in the dash, if that's the case they are connected up as part of the front door speakers
are you sure the internal amp on the CD player is turned on
Old 04-11-2009, 07:34 PM
Still no luck yet. As far as I know the new deck I bought doesn't have an internal amp.
Old 04-11-2009, 08:09 PM
Audio Guy
then what are you using to power the speakers ?
Old 04-12-2009, 12:03 AM
AWP9521 AWP9521 is offline
Is it possible there is a factory amp in the vehicle and you don't have the remote (Power antenna lead on the harness kit connector) power lead connected to turn the amp on?
Originally Posted by AWP9521 - 02/16/2005
Sure sex is a thrill too, but your modified car will never tell you
"Sorry honey, I just don't feel like it tonight" it will always be in
the garage silently waiting for you to hop in so it can thrill you
some more, that is unless you break it. At least they're easier
to repair and get the thrill back than a pissed off girlfriend.
Old 04-12-2009, 01:14 AM
As far as I know the deck is supposed to power the speakers. Im not running an amp, but the factory stereo is a Bose premium deck with a built in amp. Im not sure what else to do. I appreciate all the helpful responses.
LGE-LG830 AU-OBIGO/Q05A1-3.8 MMP/2.0
Old 04-12-2009, 11:30 AM
Audio Guy
APW is saying that often times in these premium factory systems the amp is a seperate box. If that's the case, you will need to either bypass the factory amp or figure out how to turn it on.
Oh yea, and the outputs from an aftermarket deck may be too much for inputs of the factory amp to handle.
