Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-09-2009, 06:50 PM
neighbordude neighbordude is offline
pizza delivery guy in need of light to light speed.
I've got a 92 eclipse gs with the stock 4g37 engine. As usual the 17 year old engine is getting a little used up. I'm not into the racing or turbos (although I do enjoy going fast). I'm just looking for any recommendations, whether to go with a better engine than the stock, or was the 4g, at new, a good engine to stick with.
Old 04-09-2009, 09:35 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: pizza delivery guy in need of light to light speed.
You got the 4g37 1.8l motor. Dont confuse that with the 4g63 motor. The 1.8l motor kinda sucks balls man. Its not made for speed at all. If the motor is in good shape you could do a few bolt ons and get a few more ponys out of it.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 04-27-2009, 04:34 AM
weave41_82's Avatar
weave41_82 weave41_82 is offline
if your looking for a better engine and may do a swap, deff go for a 4g63t. much stroger and quicker motor. Although you might have issues matching them up in a base model eclipse. at that point with all the work you would be better off jus buying yourself a gs or even a gst or gsx then you would throw awd into the mix.
Old 07-13-2009, 06:55 PM
CaffeineTripp's Avatar
CaffeineTripp CaffeineTripp is offline
Send a message via AIM to CaffeineTripp Send a message via MSN to CaffeineTripp Send a message via Yahoo to CaffeineTripp
If you're going to be using your car for delivery driving, I'd definitely stick with the 4G37 1.8 liter motor. It's quite the workhorse and I should know, I've driven one for over a year delivering pizza and it never quit on me (except for recently though while not delivery driving).
If you're not looking for a big project and just want to get some more horsepower out of the engine, and better gas mileage, there're many things that you can do to it. It may not seem like there's a large aftermarket support for the engine, but basically anything can be found and has been found. From the cam, to the valves, valve springs, rods, pistons, transmission. Tons and tons of stuff is available fort he 4G37 motor and the FM522 transmission.
Here's a couple of good links you might want to check out:
www.DSM1Eights.com
www.4G37Tuners.com
www.VFAQ.com
www.DSMTalk.com
Tags
1992 , eclipse , engine , mitsubishi , swap
