2002 grand prix gtp brake control module?
my abs light and my traction off light are both on. i had it scanned and the codes that came up are co750 co550 and co274. what is wrong and what do i need 2 change. brake control module? all 4 bearings are good and check out
Re: 2002 grand prix gtp brake control module?
What brand ABS scan tool was used? Those DTCs are just generic garbage and you cannot rely on them. Plus they do not match any listed for GM ABS Mark VI or GM/Bosch 5.3 ABS systems. GM ABS DTCs start with C1XXX.
Could be the electronic brake and traction control module (EBTCM), ABS modulator/motor pack, solenoids or wiring.
it was a snapon modis with 9.2 software
Thats not good enough or dependable on retrieving ABS DTCs and properly translating to determine what component is causing your issue. You need a GM Tech 2 scan tool.
what do you think it could be? wires look good and all 4 bearing are good front are brand new. when i bought the car the light was on and the front bearings were bad( 40mph hum) so changed them and light didnt go off. but sounds a lot better anyway. my rack is leaking and i have a new one just didnt get a chance to change yet. could the rack set a code?
For 1999 and up GPs a common failure item is the EBTCM module which is located at the front of the ABS motor pack/modulator assembly below the master cylinder where you see that big electrical connector going to it. Expensive part but there are companies on the NET that repair them at a much lower cost.
what ab out changing it with a used one?
No problems as long as it is good. Be sure to get one specifically for your year GP or double check the GM/Delco part numbers. There are variances through the years, I think Ed Morad sells them used separately but double check. Many salvage yards prefer you pull the whole ABS/EBTCM/Motorpack assembly.
yea he has one for 199 good price? yea ill take whole unit
Hard to beat that price for the whole assembly. GM list is way above $800 or more. I'll have Rich - Richtazz confirm what it costs new. He is our GM/Delco parts expert.
the EBCM is the same for all GTP's from 1999-2003. The part number is 88894774 and runs $789.37 dealer wholesale. Actual dealer retail is over $1,000. The part is GTP specific, so one for a like year GT or SE will not work for your car. I would say $199 is an awesome price.
If you were thinking used, here's the part numbers to avoid for reference, as they won't work in your GTP. the SE models use part #12458914 for model years 2000-2002 the GT models use part # 88894775 for model years 1999-2002
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
Any Help would be appreciated thanks |
welcome to AF mastamind51
The part number they gave you is correct for your vehicle. About all I can suggest is either comb the salvage yards for a 99-03 GTP and verify the part number or bite the big bullet and buy a new one from the dealer. Good-luck!
is this a common problem with the grand prix gtp? is it ok to get a used ebcm or is it preferred to get a new one at gmpartsdirect.cxx?
No problem with a used one as long as it is good. The problem with any sources such as the dealership or even gmpartsdirect is the part will be expensive. Also, there are sources that rebuild EBTCM modules.
