Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 04-08-2009, 01:26 PM
1996Chreokee 1996Chreokee is offline
2004 Crown Vic - heater blower motor
Hello everyone,
I am enjoying my 04 Crown Vic. I got it for a great deal. I do and some small complaints and was wondering if I could get a little help. The problem is with the blower motor. It works on 1 and high all the time and only on fan speed 2 and 3 some of the time. I know other models have resistor cards but when they are bad it only works on high. (all the time)
any help would be great
Old 04-09-2009, 09:09 PM
rhandwor rhandwor is offline
Re: 2004 Crown Vic - heater blower motor
Does this have climate control or a regular heater?
Old 04-11-2009, 06:27 AM
Good morning thank you for your reply.
It has just the regular heater.
Old 04-11-2009, 06:39 AM
As you have power all the time and ground or it wouldn't work on high. I would try a new resister the older ones had two in one so part of it could be failing.
Look along the firewall about the center on top of the heater case.
Old 04-12-2009, 10:04 AM
Stick462 Stick462 is offline
looking at your engine the relay is on the right end of your heater box just behind the right valve cover with 3 wires connected.
Old 07-17-2009, 09:05 PM
SOLEMI99 SOLEMI99 is offline
I got 2005 crown vic 235,000 milage on it i got new battri the alternator is working but but after four hours parking it drain the battrie/////
big headach every time jump cable
Old 07-18-2009, 06:46 AM
Disconnect the ground wire use a DVOM between the ground wire and the cable set to amps. Get a reading after the under dash lights shut off. Pull one fuse at a time until the drain goes way down. When you find the general area disconnect one item at a time until you locate. I've had an alternator drain the battery disconnect this to check this item. Sometimes a fuel pump relay will go bad and cause this. Normally you will have a small drain for clock and ect.
Old 07-18-2009, 12:40 PM
Your problem with the battery going dead after a few hours could be broken wires from the under hood wiring harness coming from the fuse panel and going down and looping across under the rad support to the computer and incar fuse panel.I would check that harness for broken or cut wiring .Ford is known to forget the wiring harness support bracket or putting a loop in the harness before it crosses the rad support giving a place for water and road junk a place to rot the harness.
