Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 04-07-2009, 04:18 PM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
twin turbo question
I searched for it and couldn't find it.
I was doing some reading and it was mentioned that twin (parallel, not sequential) turbocharger setups have less lag than a single turbo setup. other than simplified exhaust piping (fewer pipe bends = better flow = less lag), i really can't see any reason for this, you've got two turbos that are half the size of the single turbo getting half the exhaust and providing half the airflow each, wouldn't that mean they'd take the same amount of time to spool as the larger one?
Mr. T doesn't pity anyone who likes the Black Eyed Peas. He just kills them.
Mr. T speaks only when necessary. His main form of communication is folding his arms and slowly shaking his head. And regardless of the situation, he is always understood.
On the A-team, Face , Haniabal, and Murdoch were all masters of disguise. Mr T didn't have to wear a disguise. The bad guys didn't recognize him out of fear.
Old 04-08-2009, 01:45 PM
534BC 534BC is offline
Re: twin turbo question
I remember it having to do with the inertia of the smaller shafts,inpellers,wheels of the 2 smaller turbos. Mostly the smaller diameter vs. the larger outer diameter of one wheel, compressor, et.
I never gave it much consideration and used whichever set-up was easiest to plumb. v-engine gets 2 usually. single exhaust manifold gets one. Many exeptions of course.
Old 05-18-2009, 08:54 PM
J-Ri's Avatar
J-Ri J-Ri is offline
That's in line with what I've learned about them. Also, some parallel twin turbos have two different size turbos. The smaller one spools up faster, while the larger one provides more boost after the smaller one drops off.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
