Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-07-2009, 05:13 PM
kshook.2's Avatar
kshook.2 kshook.2 is offline
95 caprice wiring harnes
what would i have to do to make my car obd2 instead of obd1 whats all involved thanks
Old 04-07-2009, 06:41 PM
96capricemgr 96capricemgr is offline
Re: 95 caprice wireing harnes
Why do you want OBD2? Many of use with 96 swap to OBD1 pcms.
The OBD1 is VERY cheap to tune and datalog and some tuners actually claim a little more power out of OBD1 on the same car back to back dyno runs.
96 Caprice Medium Garnet Red
11.56 at 115.9mph naturally aspirated
94 Caprice wagon, rotted out POS
Old 04-07-2009, 07:29 PM
mike561 mike561 is offline
What i like about OBD 1 is how you can do the little paper clip trick to short the 2 terminals and count the check engine light blinks to determine which error codes you have, not sure if you can do that wit all obd 1 systems but i know on my 83's dinosaur computer you can
2006 Chevy Cobalt LS
Old 04-07-2009, 08:25 PM
Blue Bowtie's Avatar
Registered Offender
You won't be able to "paper clip" the 1995 ECM for either the L99 or LT1. You would need that ECM to use the OptiSpark, and that ECM requires a bi-directional scanner to retrieve codes.
Old 04-07-2009, 09:06 PM
thats what i thought, i knew later obd 1 systems would be a little more advanced then the early ones. jus curious, up to what years were you able to paper clip an obd 1 system?
Old 04-07-2009, 09:15 PM
kshook.2's Avatar
when it comes to the hypertech power programers do they do the same on obd1 as obd2 or what
Old 04-08-2009, 06:44 PM
What they are is garbage. You can buy the datalogging software, the programming software and the data cable for OBD1 for less than that POS cost too.
In other words looking to swap in an OBD2 pcm so you can run Hypercrap is a REALLY REALLY BAD idea. Granatelli is garbage too, as is Jet, "throttle enhancers", IAT resistors, B&M shift improver and lots of other "simple upgrades for computer controlled cars".
If the programmer was given to you sell it on ebay, if you bought it try and return it.
Old 04-10-2009, 01:22 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
I would definitely listen to what '96 has to say about this, he's an expert with this stuff. You're better off with a laptop computer with the proper interface cable, and programming software to do the job. Like he says, it's cheaper and the end product is better.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
