Old 04-07-2009, 03:14 PM
all power all power is offline
Talking 99 gtp
hey guys im new here and just bought my first GP. now ive gone to different web sites to fine little mods i can do . are they any tips/tricks i can do without spending alot of money? i want to get a underdrive pulley for my super but dont know want size? and the car is all stock any clues and whats the best muffler to go with? wires/plugs/coils any insite will be helpful
Old 04-07-2009, 06:59 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 99 gtp
Welcome to AF!!
Before you change the pulley on the supercharger you need to do some additional mods to the car to maximize the performance. At a minimum you will need to do a cold air intake, do a U-bend delete to open up the exhaust or better yet install headers with a high flow cat and a catback exhaust. You should consider colder plugs and I would get the PCM reprogrammed to take advantage of the mods once you do everything else. Good Luck!
Old 04-08-2009, 04:21 PM
Wink Re: 99 gtp
Will i hurt mgps that bad because right now im getting 22city runnin 93
Old 04-08-2009, 04:30 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Re: 99 gtp
Smaller pulley = more boost = more fuel needed = worse mpg. However, intakes and exhaust mods can actually improve mpg. However, with bolt-ons you can still achieve pretty decient mpg.
Old 04-08-2009, 07:06 PM
Pontiac Guy
Re: 99 gtp
Actually your mileage will only suffer if you keep your foot in the supercharger. If you are like my son that likes the SC as much as possible the mileage will certainly suffer. However, if you are like me and only use the SC when you need it the mileage should stay basically the same if not improve once you open up the exhaust.
Old 04-08-2009, 09:45 PM
VR43000GT's Avatar
Re: 99 gtp
True GTPDad. Staying under boost unless needed you may in fact gain some mpg. While I have not driven a GTP enough (nor I guess did I pay attention to this) to know how easy it is to slip up into boost but the easier it does the worse mpg you will get. On stock 9B turbos on my VR4 it is actually somewhat difficult to stay out of boost while accelerating in 2nd and 3rd gear as they spool up so quickly since they are not terribley large turbos.
Old 04-09-2009, 02:27 PM
Re: 99 gtp
every site ive been to a cat-back kit runs about 500$ headers arent bad around 200$ but they are ported and i dont think they atre real headers? they look stock but are ported does it make a diff? and if i go with cooler plugs and stat? what temp,autolite plugs? and #.wires im thinking msd,coil pack msd? and like i said im a F.N.G. besides im used to the old school GPs 70-87
Old 04-09-2009, 06:57 PM
Pontiac Guy
Re: 99 gtp
Try this! http://www.pfyc.com/c/GPEXH/Exhaust.html They are reputable and the prices are reasonable. You may also want to check ZZPerformance.
Old 04-10-2009, 01:56 PM
Re: 99 gtp
another quick ? how do i keep my daytime running lights off ? is there a trick without cutting or melting anything? and whats the diff if i go up to a muffler shop and tell them i want new pipes from the highflow cat back and just buy some dynomax mufflers? im thinking it would be cheaper....oh yea i see gt/gtps were the wipers are in the middle of the windshield? is this something im going to have to deal with? was i right about wires/plugs/coil pack? MSD''''and what number on the plugs should i look for. for a cooler plugs
