Old 04-07-2009, 09:35 AM
kega2 kega2 is offline
i need help
pls i have cherokee sport i have been sufering of over heatin last 3mont change gasket change radiator remove tha termostat still hapening
Old 04-07-2009, 04:23 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: i need help
Overheating. You say you have removed the thermostat and also replaced the radiator?
Does it overheat while driving slowly in traffic, on the highway, or both?
Your might have a bad water pump; can you see the coolant moving inside the radiator?
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 04-07-2009, 04:38 PM
ctwright ctwright is offline
Re: i need help
Did you install a new thermostat? Leaving none in the housing doesn't allow the coolant in the radiator enough time to cool before going back to the block. Your coolant would just be flowing constantly that doesn't help with anything, you need the thermostat to allow coolant time to cool in while in the radiator, when the engine gets hot enough, the thermostat will open and the hot coolant from the block will enter the radiator and the cooler coolant from the radiator will enter the block to repeat the cycle again.
More than likely if something was there to start with it was there for a reason.
Old 04-08-2009, 12:39 PM
runuover runuover is offline
Re: i need help
try flushing the system i had to do it about 3 times before mine quit over heating
