Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Avalanche
Old 04-07-2009, 07:55 AM
ffgus ffgus is offline
Rear gears swap
2005 1500 Avalanche, 4 X 4. Does anyone know if 4.10 gears will fit in a 3.42rear end housing?
Old 04-07-2009, 08:49 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Rear gears swap
THAT IS WAY TO LOW GEAR RATIO FOR HWY WAY DRIVING.
Why are you swaping
THIS LINK SHOULD HELP.
http://www.differentials.com/install.html
MT
Old 04-07-2009, 05:35 PM
Re: Rear gears swap
I want to pull a 4800 lb travel trailer, and was told that the 3.42 rear end will be way too doggy if I encounter any hills...
Old 04-07-2009, 06:36 PM
maxwedge maxwedge is offline
A990 racer
Re: Rear gears swap
Yes they will fit, but a 3.73 will get the job done unless you have really large tires.
Old 04-07-2009, 06:50 PM
MT-2500's Avatar
AF - Advisor
Re: Rear gears swap
Due to the expense of changing both front and rear and loss of fuel mileage I would try it as is.
But make sure you have a big extra transmission cooler.
Good Luck
MT
Old 04-07-2009, 08:33 PM
wafrederick wafrederick is offline
Banned
Re: Rear gears swap
Plus the 4x4 will not work right.
Old 04-08-2009, 08:22 PM
Re: Rear gears swap
Thanks for the help. I am going to have a tran cooler installed tomorrow.
