Old 04-07-2009, 12:47 AM
slowsuki1 slowsuki1 is offline
00 buick lesabre turn signal problem
i have a 00 buick lesabre that i am having problem with no turn signals. it first started with the infamas fast blinker on drivers side, so i replaced all the bulbs , so when that did not fix the problem, i thought it was the socket, but it turned out ok, so i replaced the flasher and after that, i have no blinkes at all, haz work but no blinkers. i tryed old flasher but still no blinkers. i checked the fuse that runs the blinkers, it was ok.i replaced it anyway.is there any hidden fuse that i missed somewhere,any sugestons ? thanks.
Old 04-07-2009, 08:01 AM
brcidd's Avatar
brcidd brcidd is offline
Re: 00 buick lesabre turn signal problem
Try looking under rear seat- on driver's side at the rear fuse block- there are lamp circuit fuses in there...
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 04-07-2009, 10:51 AM
the only fuse that i could find that was marked for the turn sig /haz was under the back seat, and that is the one i replaced wich looked fine but you never know. i am wondering if there is a fuse in the colum or hidden under the dash that is not able to see.
Old 04-07-2009, 12:49 PM
brcidd's Avatar
Should also be a related fuse in the under hood fuse block
'99 GMC Yukon
Old 04-07-2009, 01:18 PM
imidazol97 imidazol97 is offline
AF -Advisor
Check IGN 1 Fuse 12 10 amp Rear Fuses
Fuse 36 15 A Rear Fuses Tsignal and Hazard
Stop lights are Fuse 19 15 A.
That's all I can see.
Old 04-07-2009, 02:01 PM
you my friend are a hero, it was #12 10amp fuse i never evean thought to look at that fuse thanks a bunch.
Old 04-07-2009, 02:25 PM
AF -Advisor
Thanks for coming back and telling us what you found.
Old 05-12-2009, 07:53 AM
pcmos pcmos is offline
Send a message via AIM to pcmos
I'd also mention to make sure you are using the correct bulbs. I've seen a number of LeSabre's cruising around with rear lamp lenses melted because someone used the wrong bulb. You don't want to overheat your lenses or potentially blow a fuse again.
The owner's manual for my 00 specifies the following:
Rear Tail/stop/turn signal (rear corners) - Bulb 3357
Trunk mounted tail lamps - Bulb 194
Trunk Mounted Back-Up lamps - Bulb 3057
Front Turn Signal - 3157
Old 07-27-2014, 04:57 PM
IHatecars7777 IHatecars7777 is offline
I am having this same issue and have changed the fuses listed in this thread. No dice. Any further suggestions? Thanks!
