2002 ranger won't start 2.3 dohc
i just put a used motor in it .and it want start. ive checked all the wires there all pluged up.i checked for fire and didnt have any.when i bought the used motor the front timing case was broke .so i replaced it .so i had to take off the crank sensor.the automotive manuel that i have says if you take the sensor off you have to replace it with a new one.is this true.would the crank sensor keep it from firing.thanks
Re: 2002 ranger won't start 2.3 dohc
I don't see why you would have to change the sensor however I can see that they would say that because probably a good time to. And yes the sensor can cause the problem you are having. First I would check power to the coil packs, should be a red/light green wire if they haven't changed much from my 90 2.3 to your 2002 2.3. Either way you should have 12 volts on one of your wires going to the coil packs.
I would try taking the sensor off from the other motor and putting it on there. I would first check for ground pulse to the negative side of your coil while turning the motor over(I said coil packs earlier but then you said coil so I guess you have the distributor type ignition I dunno), if you are getting one the problem is coil. I can't remember if you said you have a new coil or not. Also to a bad ignition module can cause no spark(getting the crank signal from ecm which gets the signal from the crankshaft position sensor but not putting out the ground pulses that are supposed to go to your ignition coil). |
Ok, you should have wires or wire tan/something at your coil. Those should get the ground pulses from ignition module, put a test light clip to a battery positive somewhere, and the probe of the test light to the wire that and it should flicker with someone turning the motor over. If it doesn't then it's either the ignition module or the crank sensor, I doubt both were bad and if the one wasn't broken after removal that didn't work the first time when you took it off then I would try an ignition module.
I know it should be noticeable if when first turning it over, I'm not sure if when an engine is running or not if its noticeable because it would be doing it so fast the light might would look steady then, but I'm not sure but either case it won't matter to you because you will be checking it while trying to crank. |
i will get out there in the morning and try that.if i learn any thing ill lit you no thanks a lot.
