Go Back   Automotive Forums Car Chat > Chevrolet > Beretta
Old 04-06-2009, 11:20 AM
plainside47 plainside47 is offline
Help, beretta just dies
HI, I am new, have a 1989 chevy beretta 2.0 liter, 4 cylinder with fuel injection, not EFI. Was just driving down the road at 55 and it just died, could not restart it it does crank over. There was no spark when I check the plugs. Let it sit overnight it restarts and idles rough for about 3 min then dies again, will not restart for many hours or overnight. Were to start on this?
Old 04-06-2009, 12:37 PM
maxwedge maxwedge is offline
A990 racer
Re: Help, beretta just dies
Crank sensor or ign module are the usual culprits. Get a scanner on it and look for cranking rpms, if none suspect the cps. Component locations and test procedures are at autozone.com, repair guides.
Old 04-06-2009, 12:43 PM
Is the crank position sensor/ignition modual hard to get at? Is this a problem that is intermitent like what I have?
thanks.
Old 04-06-2009, 12:53 PM
jsgold jsgold is offline
The igniton module can be intermitent, usually starts with hard starts, random stalling until it fails. Usually when they get hot they act up also. The crank sensor usally fails and that is it. You can remove the coil pack/module assembly and have the module tested at Advance/NAPA/Autozone for free. it is a flat module, sits under the coils.
I used to be indecisive, now I am not so sure.
Old 04-06-2009, 06:46 PM
A990 racer
Tough place to get to, I believe it is at the rear lower area of the block. The cps is right under the icm in that area.
Old 09-22-2009, 09:06 PM
loosenut74's Avatar
loosenut74 loosenut74 is offline
Send a message via Yahoo to loosenut74
It's on the back side of the block (between the block and firewall) three wires go to it. Its about in the middle of the block, about two inch's up...
Removed by Moderator
The Following User Says Thank You to loosenut74 For This Useful Post:
jdonojr (06-27-2011)
