Go Back   Automotive Forums Car Chat > Nissan > Older Pickups
Old 04-06-2009, 10:39 AM
infotraker infotraker is offline
86 D21 6 cyl 4wd engine stops running
Running good then engine stopped . Will start and idle for few secs. then stops. Will run very badly if you constantly move the gas pedal. Plugs, rotor,cap, coil good. Changed fuel filter and fuel pump, no change. Checked computer and it says ecu input sig. beyond the normal range. Could this be a ox sensor problem ? Any other ideas ?
Old 04-07-2009, 07:22 AM
Gunshot Gunshot is offline
Re: 86 D21 6 cyl 4wd engine stops running
I also have a 86 D21 but it's a 2wd with 638,250 miles. Mine did this at about 250,000 and I changed the catalytic converter and solved the issue.
Gunny
Old 06-06-2009, 02:01 PM
rickd_kc rickd_kc is offline
I have a similar problem. Any resolution yet
