Old 04-05-2009, 11:24 PM
mbrown519 mbrown519 is offline
95 grand am 3.1
I have recently fixed my starting problem and now it will not idle(just dies if your foot is not into the accelerator) i have checked for codes and it came up with 24x cranksensor/3x cranksensor(both just replaced) cam sensor and o2 sensor rich. I have cleaned the throttlebody/iac and replace throttle position switch. It has a new computer and fuel pump and filter. all sparkplugs have good spark and i cannot figure out why it will not idle. any help with this nightmare would be great.
Old 04-06-2009, 03:59 AM
3100 3100 is offline
Banned
Re: 95 grand am 3.1
because you need to do CKP relearn procedure
any time you replace: CKP or PCM do the relearn procedure with appropriate scanner
Old 04-06-2009, 06:03 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: 95 grand am 3.1
Welcome to AF mbrown519 !!
try that and see if it runs better.
1999 Grand Am SS 3.4 OHV
Old 04-10-2009, 01:53 AM
Re: 95 grand am 3.1
Is relearning the computer the same as flashing it? And what special computer would I use to relearn it at home? Thanks for the help.
Old 04-10-2009, 02:46 AM
Banned
Re: 95 grand am 3.1
scanner that can read live data, trans, abs, ipc codes most likely can do ckp relearn.
your car should be free form any other codes, and should be at normal operating temperature as such it can be completed in 5 min. So go to GM dealer for an oil change ask them if they can help you with that.. maybe they do it for free. honestly 3 min the most. But that is only if you are 100% sure that you do not have any codes.
Old 04-11-2009, 10:43 AM
Re: 95 grand am 3.1
Only a select few , like the stealership, can "flash" a PCM . I guess Digital Horsepowr and MMS can also flash them.
As 3100 stated a highend scanner can easily do the CKP relearn.
