Well, my brakes lights stay on whenever they feel like it. Most of the the time they get stuck on after 30 minutes or so. This is only when car is running and in gear ( auto trans ) Will not do it if car is in park or ignition key on. Only when engine is running. It did happen one time after 10 minutes of driving, but only once.This started about two months ago, at that time I started replacing parts. I've read every single post involving the brakelight/hazard problem. I've also read literally 100's on other forums with no resolution. The 2000-01 Focus is the only year that uses the hazard switch to also work the brake lights, tails only not the 3rd brake light. I replaced the stop light switch twice, no change. I have used three different hazard switches, problem returns no matter which one I use. One is factory original, one less then a year old, and one brand new. All are Ford parts, no aftermarket. So those two items are fine. I completely disassembled all the rear wiring and cleaned all contacts and grounds, no change. Not a fuse problem because I do have working brake lights most of the time. Check wiring going into hatch, peeled back rubber boot and repaired any exposed wires. This is quite common in the Focus hatch, so that's the first thing I did. No change. The directionals will flash when lights are stuck on until last night. I went for a 30-40 minute ride and the lights got stuck. I can see the glow from my side mirrors, of course only at night. I never know during the day. The only way to shut them off is to unplug the hazard switch, but that's only cutting the power source. If I wait for 15-20 minutes and plug it back in they will stay off. The switch does get warm but that's because the lights are on, it stays cool when lights not stuck. Back to last night. When I got the car home I put it in neutral and tried the turn signals. I put the right turn on and the left side was blinking. WTF ! I got out and checked, the lights were flashing like a school bus. Each side flashing opposite of the other. Is something heating up after awhile ? I have no clue. This year Focus does not have a separate flasher unit that I could try. It's all through the hazard switch.
New stop light switch(2)=nothing
New hazard switch(3)=nothing
Hatch wiring repaired=nothing
New multifunction switch=nothing
All fuses good
