Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 04-05-2009, 07:36 PM
derberg derberg is offline
No heat in 2000 Town Car
The heater in our 2000 Town Car has grown weak and now emits no heat. The fan, temp and position settings, and A/C work, but not the heater/defroster. It blows only ambient air. Any ideas of what's wrong?
--Tom in Ohio
Old 04-06-2009, 09:25 PM
danielsatur danielsatur is offline
Re: No heat in 2000 Town Car
Check:
Car Forums -> Lincoln -> Town Car
Search this forum ''No Heat''
KEEP a good eye on your Engine Temp guage and make sure it stays in normal operating Temp.
Old 04-06-2009, 10:26 PM
Kitt1993's Avatar
Kitt1993 Kitt1993 is offline
I wonder if your car has that valve like some ford vehicles that transfers the coolant to and from the engine, and when you switch it, then it goes through the heater core. You might want to check that out.... Just a thought..
B
Nick names for my Car....
Abe Lincoln, opcorn:
The President,
Lucky Number 5
Old 04-10-2009, 09:47 PM
fireplow fireplow is offline
Hey I had the same trouble with a 95 I found a vac line under the dash that was loose (i think it was gray) hook it back up the damper and the heat worked great. No there is no valve in the heater line. Now there maybe a pluged line. Allow the motor to come up to temp. and feel the heater lines if both fell hot then no plug. Now if one fells hotter than the other then pluged line. Flush the line and see what happens. I hop this helps.
Old 05-21-2009, 05:27 AM
airexcursion airexcursion is offline
check your blend door motor having trouble with one right now.
