Old 04-05-2009, 04:17 PM
Fastshivy Fastshivy is offline
01 2.4 timing chain tensioner problems
Replaced the timing chain, sprockets and cyl head on my 2.4 GA The car has been running fine, but the chain is noisy at idle. When I intially took the tensioner off the piston fell out so i looked it over reassembled it, and it appeared to be in good shape. When I re installed the tensioner it was loose and sloppy. I figured when the car was cranked up oil pressure would send the piston out and take up the chain slack. It is almost like it is bleeding down at idle/shut off. Took the front timing cover off and the piston in the tensioner is retracting when the car is shut off leaving the chain temporarily sloppy. Most tensioners I have seen have a check ball or ratchet system that keeps tension on the chain even when the car is not running.....is this a poor design or did i do something wrong?
Old 04-06-2009, 06:02 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: 01 2.4 timing chain tensioner problems
If you used the old tensioner its probly bad/broken.
These are held out by a spring inside the piston, not oil pressure, so it should be always tight.
1999 Grand Am SS 3.4 OHV
Old 04-06-2009, 06:39 PM
Thanks That is probably why it sounds like a diesel!! A spring?...no wonder GM is in the toilet
