Old 04-05-2009, 03:46 PM
buckymarino buckymarino is offline
no start: turn key, hear click, all power cuts out
94 f250 5.8
the truck has a brand new starter (the problem happened with the old starter too)
when i turn the key, i hear one single click and the power cuts out. i can't attempt a second start or turn on the lights or have any power going through the truck until i disconnect and reconnect the battery. then ill get back in and try again and it cuts out again. anyone ever run into this? i tried the search feature but anyone else with a similar problem was told to put a new starter in.
thanks a lot in advance
Old 04-05-2009, 05:00 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: no start: turn key, hear click, all power cuts out
Sounds like you have a bad connection in the system. urning the key makes too much current go to the starter and the connection fails with the extra load.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 04-05-2009, 05:10 PM
would the next logical step be to test the relay? this truck has the fender mounted relay/solenoid. from what i see, tihat it is the next component in the chain.
Old 04-05-2009, 10:01 PM
Idaho_Mechanic1984 Idaho_Mechanic1984 is offline
Send a message via Yahoo to Idaho_Mechanic1984
Quite a few times with this problem I cleaned the connections thoroughly at the battery and made sure it was tight and the problem never happened again.
People said to put a new starter - because sometimes an internal short in this would cause that - but I always make sure sure all the connections are clean, strong, and tight and that usually takes care of it.
If nothing still - you may look more into your ignition switch setup/wiring....
Dale
Old 04-06-2009, 01:21 PM
FNA FNA is offline
I don't know why you were advised to replace starter when the problem is systemic electrical failure.
Induce the condition, start at the battery and find where/when you no longer have power.
But I agree, clean up all connections first.
Old 04-16-2009, 03:19 PM
LoseDevil's Avatar
LoseDevil LoseDevil is offline
Have you had the battery checked? I had a bad cell in a Dodge I own that caused kookie results much like what you are describing. The computer knew the battery was bad, but only responded with erratic starting and even idling once started.
Old 04-18-2009, 02:25 AM
stinger196924 stinger196924 is offline
It doesn't sound like it is the starter, it sounds like there is a problem with the bat. terminals or the connection to the wires in the terminals. if not check the connection to the solenoid. but i doubt that it is in the starter.
Old 06-21-2009, 04:24 PM
Yardpilot Yardpilot is offline
I have two trucks that did something similar. On the 74 it turned out to be a bad ignition switch. It was coming apart inside. The truck was burning coils. On the 73 it was a bad starter relay. Sometimes it wouldn't start. Sometimes it wouldn't shut off. Sometimes the battery would drain off overnight. Both are fine now with simple replacements. No more burned coils, no more dead batteries.
Yardpilot
Old 06-22-2009, 03:08 AM
Godofwarmike's Avatar
Godofwarmike Godofwarmike is offline
check your wiring harness for corrosion. my dad had an old truck around that same year that had some cracked wires. got corroded and would make it act just like that.
1999 Purple Plymouth Neon SOHC Automatic
Bought Feb 2009 For $700
125,000 miles
Maybe the world record for car with most hidden zip ties
Old 06-30-2009, 09:19 AM
ghalacsy ghalacsy is offline
i had a grand marquis that did the same thing until i replaced and tightened down the terminals on my cables. that fixed the problem for me.
