Old 04-05-2009, 02:55 PM
mva5142 mva5142 is offline
valve cover oil leak?
I have a 2002 chrysler voyager, 105,000 miles. I think I have a valve cover oil leak. oil seems to be over the length of the engine on the backside. Also see a spot or two from the front side valve cover. Is the there anything else on the backside that would leak like that? Also, what else should i do while i have everything off. I plan on changing plugs, wires, pcv valve, maybe the oxygen sensor while i have it all off.
In addition i am going to be dropping the transmission pan and replacing that gasket with RTV as it is leaking tranny fluid. i plan on doing the trans filter then as well.
Thanks
Matt
Old 04-05-2009, 10:35 PM
littlebitofinsanit littlebitofinsanit is offline
Re: valve cover oil leak?
just becareful messing with tranny pan you cant get gasket at dodge but you can at other parts store same as rear diff pan cover com leak area traans fluid and tran dip stick remember wen using af mention year make motor size and tranny when asking
you"ll be alright
Old 04-06-2009, 03:28 PM
iwannagofast iwannagofast is offline
back valve cover leakage on them motors is very common(a lot of heat build up).The only other place it could leak back there is the head gasket which isn't likely. You have to take the wiper cowl off in order to remove the valve cover.It's easy just watch out for rusted nuts.
Old 04-07-2009, 07:46 AM
Thanks. I was wondering if it is eassier to remove the wiper cowling or the upper manifold/ throttle body assembly. Looks a little less involved to take the wiper cowling off.
Thanks for the guidance.
Matt
