| Off-Topic Talk about anything other than cars. |
Head gasket job
Ok well as you well know my HG blew out attempting to use nlts. I'm not saying the NLTS was the cause of the failure I'm just saying it happened when it was engaged.
The gasket looked pretty bad. There was supposed to be a cometic in there but when I got it off it looks like the guys who did my engine rebuild just put on some composite thing that blew out. ![]() |The damage was done on the far front left side of the gasket near cylinder one (or the first passenger side cylinder) ![]() The metal seal where the oil flows is clearly damaged and there was some warpage above that on the gasket. So thats the bad The good Cams look great! ![]() Cam gears No problem ![]() Pistons no hot spots or metal shavings! ![]() Block no cracks or deep scrapes etc ![]() Thats where its at right now Still nervous about this IM fitment. Time will tell!
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM. 18 Inch chrome rims In closet AEM Fuel Rail, SS Lines, 1997 TSI AWD Diamonds Are 4Ever 12.7 @ 107 http://i83.photobucket.com/albums/j2...y/DSC00461.jpg |
Re: Head gasket job
Sweet! Looks good so far.
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
Re: Head gasket job
Looks like someone forgot to drain the coolant out of the block before pulling off the head haha. I've done that before... makes a hell of a mess. You probably already know this but, FYI, there is a very short hose on the driver side of the car in the front by the oil filter housing(I think) you can pull off. This will completely drain the entire coolant system.
Congrats on everything being in good shape. It sucks getting that composite stuff off of the block. I used a razor blade and did it by hand. After a few head gasket jobs I bought this rubber bristle attachment for an air drill. Works great but, you have to go slow. Still faster than a razor blade.
95 GSX 5 speed 2.3L stroker bored .020 over Built head Bullseye/Borg Warner T04B 57 Trim Turbo RNR 3" turboback w/ o2 eliminator 255 lph Extreme Motorsports fuel pump Extreme Motorsports mbc SAFC Greddy Type S BOV FMIC (core 28x10.5x3.5) FIC 650cc fuel injectors RK Sport Fuel Pressure Regulator My Car Domain |
Re: Head gasket job
Looks good man, glad nothing else got damaged.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
Re: Head gasket job
Re: Head gasket job
That's what she said...
-Brian
Re: Head gasket job
That reminds me of when I changed the HG in the Thunderbird. Everything is looking good. Keep the pics coming when you install the SMIM
Re: Head gasket job
UPDATE TIME
Made a lot of progress all things considered it should be done TOMORROW CANT WAIT found that the exhaust mani gasket had a crack in it so its gone ![]() Lowereing the beauty and the beast into position on some brand spankin new ARP head studs ![]() Hows that for fitment! ![]() Time for the water next and etc to get reattached ![]() Attempting to show the head studs getting clamped down to torque specs ![]() Attached my new 2.5 ID 90 degree coupler . It was a tad small so it was hard to get on but I made it work with some help ! ![]() Then I had to take it off again to cut off a half an inch to make it line up better with my uicp and also create new room for the battery ![]() Clamped down hard that coupler isn't going anywhere also note the room left for the small bat going in
Re: Head gasket job
timing belt back on and ready for everything to start getting reattached and finalized !!
![]() Thats where she sits right now! LMK what you think! Im pumped
Re: Head gasket job
Looks awesome. Im not so sure I would advise workin on your dsm tmrw though.
Re: Head gasket job
lol NEVERMIND figured it out that will be afterwards happy 420
Re: Head gasket job
Good job. I've had to do a few head jobs on cars. Sucks the first time, but not so bad after that. I was about to say you might as well go ahead and throw some cams in there while you got it apart, but then I looked at your mod list and realized that you already had them. Get it back up and running and pull us some 3 sec 0-60 runs.
Caleb vanilla gorilla '99 Spyder 2.4 5-speed - Red/black,14b,slow '96 Eclipse GST 5-speed - Paint www.myspace.com/ballsoutperformance |
Re: Head gasket job
Congrats on the progress so far. Looks great. What SMIM did you put on?
Re: Head gasket job
I don't have any new pics yet I will snap some. My coil pack is mounted where the egr valve used to be. I gotta clean up some vac lines and hopefully the spark wires too but shes running strong ![]() Its a 2g JmF street version! polished w/ oem map sensor bung. From Extreme that would cost over 600 us plus shipping to canada. I got it for 400 cad new cause I'm a hustla haha
Re: Head gasket job
Glad to see its back on the road
