Old 04-05-2009, 01:25 PM
mazsand mazsand is offline
97 Voyager AC Clutch/Coil Replacement
Is there enough room to replace the AC clutch/coil on the compressor without removing the compressor from the car?
Old 04-05-2009, 01:45 PM
Scotty89's Avatar
Scotty89 Scotty89 is offline
Re: 97 Voyager AC Clutch/Coil Replacement
When i looked up the removal procedure it doesnt say anything about removing the compressor itself. But you may have more room if you take the compressor off. Id try it without taking it off first and if all else just take the compressor off. If you need help holding the compressor pully you can use a band type oil filter wrench to help hold it.
