Old 04-05-2009, 12:19 PM
MNSubbie MNSubbie is offline
Front Driveshaft removal?
I need to take the front driveshaft out of my 2000 Blazer 'cause the CV Joint is worn and vibrating. Can handle the front U-Joint just fine, but what about the rear joint?? How does that separate from the transfer case? Is it a shaft with a snap ring that simply pops out? Or is there more to it than that? Help/advice would sure be appreciated.
Old 04-05-2009, 08:31 PM
old_master's Avatar
Advisor/Moderator
Re: Front Driveshaft removal?
The driveshaft does not need to be removed to replace the either CV joint or the half shaft assembly.
You have to know how it works,
to figure out why it doesn't.
Old 04-05-2009, 08:37 PM
djd99's Avatar
djd99 djd99 is offline
To take out the front axles you need to remove the brake caliper and rotor.. Then pop the lower ball joints loose to gain access to the axles.... take a pry bar and pop the axles out of front diff. Should take about a couple of hours if ya never did it before.
2000 S10Blazer LT 4 Door 4x4
Billet Grille insert
Winter 30X9.5QR15 BFG's All-Terrain T/A KO's
Old 04-06-2009, 12:56 PM
b1lk1 b1lk1 is offline
You are thinking about the half-shafts from the front differential to the tires. He is talking about the driveshaft (atleast that is what I think) which also has a CV joint where it joins the transfer case.
