Old 04-04-2009, 10:12 PM
toddomen toddomen is offline
car won't start
I have a 97 grand prix with 3.8 with 132,000 mile good spark new fuel pump new fuel pressure regulator. all parts from auto zone help
Old 04-05-2009, 12:32 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: car won't start
Are you getting the 2 sec fuel pump prime at ignition to ON? How about fuel pressure per specs at the front fuel rail?
Timeslip 08/12/06
AF Community Guidelines
Old 04-05-2009, 09:02 AM
Re: car won't start
it is 52psi down to 46 w/ key on and 50psi cranking the engine
Old 04-05-2009, 09:07 AM
BNaylor's Avatar
Re: car won't start
Thats good and you sure there is spark? Did you get it scanned for any possible history odb-ii codes? And are the fuel injectors firing?
Timeslip 08/12/06
Old 04-05-2009, 09:18 AM
Re: car won't start
I took the coil wires off and was getting good spark between the 2 posts. The codes that came back were random misfire, mass airflow & heat oxygen sensor #po135, po#107 and po#300
Old 04-05-2009, 09:22 AM
BNaylor's Avatar
Re: car won't start
Disconnect the MAF sensor and see what it does.
Timeslip 08/12/06
Old 04-05-2009, 09:24 AM
Re: car won't start
I did that and still will not start
Old 04-05-2009, 09:33 AM
BNaylor's Avatar
Re: car won't start
Did you check all relevant fuses to make none are blown. Like to the PCM module and sensors. Check IGN1 - UH at the main engine compartment fuse box. 80 pin connectors at the PCM module?
Timeslip 08/12/06
Old 04-05-2009, 10:29 AM
Re: car won't start
The fuses were all good and I did a noid lite test all good
Old 04-05-2009, 03:23 PM
Re: car won't start
I was able to finally get it started and now I have 2 codes po300 and po502. Any suggestions?
Old 04-05-2009, 05:03 PM
BNaylor's Avatar
Re: car won't start
The P0502 DTC is an issue with the Vehicle Speed Sensor (VSS). Located on the right side transaxle extension.
How old are your spark plugs and ignition wires?
Timeslip 08/12/06
Old 04-05-2009, 07:30 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: car won't start
Is the P0300 a history or current DTC?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 04-05-2009, 08:08 PM
Re: car won't start
I pulled the plugs and they were soaked with gas. I cleaned them and reinstalled them and cleared the codes, no issues at this time. I am now thinking the whole problem may have been a bad fuel regulator dumping too much fuel.
Old 04-05-2009, 08:20 PM
tblake's Avatar
In God We Trust
Re: car won't start
It could have. Did you replace the O-rings on the new regulator? (if it didnt come with new ones).
Old 04-05-2009, 09:59 PM
Re: car won't start
yes come with new ones thanks for the help
