Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 04-04-2009, 09:40 PM
pencilneck0 pencilneck0 is offline
PCV Valve?
I drive a 1999 s/w how often do you replace the PCV valve? Is there a way to test my existing valve?
Old 04-05-2009, 07:02 AM
s1120 s1120 is offline
Re: PCV Valve?
IMHO they are not worth checking. There cheap enough to just replace. I ended up changing mine for the first time at about 80k. Not sure if it was bad, but I was doing a tune up, and a valve cover gasket so I did it. Check the hoses going to it. Mine rotted out at about 150K. So if you got miles on the car, not a bad idea to check over that hose, and the breather hose to the intake tube.
Old 04-05-2009, 06:39 PM
RC1488 RC1488 is offline
Re: PCV Valve?
I have never replaced mine on any of my s-series so far. However I do clean and inspect them. They are the one part that is supposed to rattle. A little carb cleaner to get it to rattle and you should be good to go.
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
Old 04-10-2009, 02:31 PM
SC2ner SC2ner is offline
Re: PCV Valve?
That's all you need to hear. Except I am even lazier. I replace them at 30K with the plugs and wires. Careful with the elbow hose that connects it to the pipe to manifold. They tend to be brittle after all these years. Try to grab it from the front as close to the end as possible. They like to break right at the 90.
Why are you trying to act hard as hell,
when you know damn well
you don't wanna feel the shell
