Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 04-04-2009, 04:55 PM
ranclark ranclark is offline
Stalling Problem
Last week my 95 Wrangler 2.5 died. At first I thought fuel pump. I removed the pump and found that the wires for the pump had been pinched and were corroded and one had broken. I spliced the wires with a new section, soldered and shrink tubed them. Jeep ran fine for 2 days and then quit again. This time after a few minutes, fired up again. Did this a few times so I replaced the fuel pump, fuel filter and the pump relay. Started right up and idles forever but will sometimes just quit while driving. After a few minutes and tries cranking, it will start right up. Checked wires and connections and can't find anything out of place.
Any help out there?
Old 04-06-2009, 03:51 PM
hoopdaddy6's Avatar
hoopdaddy6 hoopdaddy6 is offline
Send a message via MSN to hoopdaddy6
Re: Stalling Problem
you might look at the idol air control motor. just had to replace mine in the xj. i was having similar problems.
