Old 04-04-2009, 03:24 PM
TDWPgtp's Avatar
TDWPgtp TDWPgtp is offline
wiper problems
last year i had a problem with my wipers that started randomly one day. the wipers ONLY work on the fastest setting. i had posted on here before and most people said try a new switch. i bought a used one that was "garunteed to work" and i still have the same problem. now im not sure whether i got another bad switch or theres another problem. also at one point last year around the same time, my wipers were experiencing GMs signature problem, wipers stuck upright, but that only happend occasionally and now never happens. lastly when using the wipers, in order to get them to park correctly i have to switch them off at JUST the right time or they stop in their place instead. so if anyone could somehow figure out this odd occurence please let me know thanks
Old 04-04-2009, 03:26 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
Re: wiper problems
with all the problems your having, i would just try replacing the whole motor assembly. someone else on here may have another suggestion for you though...
Old 04-04-2009, 05:12 PM
TDWPgtp's Avatar
Re: wiper problems
well the thing is i dont want to replace the motors or anything that doesnt need to be replaced. if it turns out that it wasnt the motor and i replaced all that id be quite unhappy. thats why im hoping that someone knows specifically what it is thats causing all this. if the motor is bad thats fine i just dont want to replace good parts
Old 04-04-2009, 06:23 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: wiper problems
Give a look in the tips and maintenance subforum. There is a write-up about how to fix wipers that are stuck in the upright position. You can try that before buying a new motor.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 04-04-2009, 07:55 PM
lefty1120's Avatar
lefty1120 lefty1120 is offline
Re: wiper problems
Still haven't seen what year car this is on!? I might have a troubleshooting manual to help you out.
Lefty
Old 04-04-2009, 09:34 PM
TDWPgtp's Avatar
Re: wiper problems
its a 97 gtp.
and the wipers dont park in the upright position anymore, they only did that for a few days. now the park wherever they are when i turn off the switch, and if they are within a few inches of the parking position, but in the process of moving away from it when i switch it off they will park correctly. i dont think its exactly the same problem as the parking in the upright position that most people experience
Old 04-06-2009, 11:19 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: wiper problems
The wiper motor circuit board is the most likely cause of your current issues. It controls speeds, delay, and park position. It is replaceable separate from the entire motor and is much cheaper. Since it's a printed circuit board, it can act up intermittently as the solder points can loosen with age.
The spring loaded cam-style crank arm and the tab on the wiper motor mounting bracket are also common causes of the park issue, but have nothing to do with speeds, nor is is common for them to intermittently work/not work.
The AC-Delco/Gm part number for the circuit board is 88958396. Dealer retail is $77.55, and if you have an AC-delco retailer in your area, you should be able to get it much cheaper. If you're thinking about going used/salvage yard, it fits all Grand Prix's 97-03, Regal/Century 97-05, Chevy Impala/Monte Carlo 00-05 and Olds Intrigue 98-02.
Good luck and let us know how it goes.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 04-06-2009, 04:20 PM
TDWPgtp's Avatar
Re: wiper problems
well i dont think that could have been any more helpful. thanks a bunch! ill try the circuit board soon and ill keep you posted. thanks again
Old 04-06-2009, 07:35 PM
doctorhrdware doctorhrdware is offline
Re: wiper problems
If possible, I would pull the circuit board and check for cold solder joints. That can cause intermittent problems.
Old 04-07-2009, 05:21 PM
00GTP4ME's Avatar
00GTP4ME 00GTP4ME is offline
Re: wiper problems
That would bug the hell out of me!!!
2000 Pontiac Grand Prix GTP 3.8L SII V6 S/C
2000 Jeep Grand Cherokee Limited 4.7L V8
1996 Chevrolet Camaro Z28 5.7L V8
1993 Chevrolet Suburban K1500 5.7L V8
1991 Ford Probe LX 3.0 V6
1986 Ford Tempo GL 2.3L 4 cyl.
