| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
91 GSX Problems. HELP!!!
I just want to start that im new to the forums and I'm looking for some help. I just bought a 91 Eclipse GSX. I bought the car knowing it did not run. The guy told me that he replaced the water pump 2 years ago then would not start. and left it alone. So I picked it up from him thinking it might be an easy fix. Ya far from it. What i have done.
I started the car. sounds like it has compression but not much. so i did a compression test. (left to right) maybe 10 on 1st two, 3rd had 140, 4th had 60. But the weird thing is that i went back to 3 little bit later then it was low too? so im thinking he put the timing belt on wrong so i took off the timing cover and i notice EVERYTHING is lined up but the cam sprockets by a tooth. but i dont think that would make the compression like that?...Also i do notice that i have no spark. Should i be looking for a cylinder head? Any Help or Questions for me? Anything would be useful ![]()
Re: 91 GSX Problems. HELP!!!
Looks like you might have bent some valves... or whatever, don't keep starting its time to take the head off... you got some work to do
How did you start the car with no spark?
1993 Honda CBR900RR 1990 Talon TSi AWD - Sold 1990 Laser RS turbo - Sold 1993 Eclipse GS - Sold |
Welcome to AF.
I would pull the head and check that out first. You have low compression so you deffinately have a problem somewhere.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
on a 2.0 according to the haynes book, the exhaust cam will rotate a tooth, and ud have to retime it before u put new belt on or ull bend exhaust valves
