Old 04-03-2009, 02:01 PM
jeff1367 jeff1367 is offline
97 Blazer 4.3 cranks but won't start
I was driving my Blazer, parked it, and tried starting it a few hours later. It would crank all day but wouldn't even stumble a little. I've replaced the fuel pump and filter, cam sensor, crank sensor, coil, and ignition control module and it still won't start. Cap and rotor were new last year and still look good so I just cleaned off the contacts. I have good fuel pressure at the schrader valve checked with a guage. I pulled two spark plugs and they have a good blue spark. I believe something is stopping the injectors from spraying. What could do this and what should I check next?
Old 04-03-2009, 03:16 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 97 Blazer 4.3 cranks but won't start
What is fuel pressure reading?
Are plugs wet or dry on end.
Always check all plugs for good spark.
Any codes or check engine lights?
Check all fuses.
97 is a bad year on ign switches.
are injectors getting 12 volts to pos side.
Have you got injector pulse?
MT
Old 04-04-2009, 01:11 AM
Check all fuses.
Fuel pressure was around 62 when I turn the key on or crank. Plugs are dry. Not sure if there were any codes. There are no stored codes, but I disconnected the battery while working on it and no new codes pop up while cranking or with the key on. Fuses are good and I replaced the ignition switch a few months ago. Did not check voltage to the injectors yet.
Old 04-04-2009, 08:38 AM
MT-2500's Avatar
AF - Advisor
Make sure you have all power at fuse box key on.
Check for 12 volts to injector pos side.
To check for fuel delivery problem.
Give it a squirt of carb cleaner and see if it will fie up.
MT
Old 04-04-2009, 12:45 PM
I will try these things when I get a chance and report back. Is it common for the fuel meter body to fail? A friend of mine has an S10 and had to replace that whole piece that controls the injectors. He thinks that's my problem but I want to be sure before I buy it because it's an expensive part.
Old 04-04-2009, 03:26 PM
MT-2500's Avatar
AF - Advisor
No it is not a common problem.
Each injector is seperate.
The VCM controls injectors not the fuel body.
Remember proper testing before throwing parts at it.
MT
Old 04-04-2009, 06:44 PM
I do have power at all fuses with the key on. I pulled the connector for the injectors and every positive had about 13 volts. I don't have any carb cleaner but I did try dumping some gas past the throttle body and the car did not even try to start or sputter. When I was checking the fuses, the only one that did not have voltage was crank, which makes sense. I checked the voltage while cranking and it was only 6.5-7. Is this normal? I also touched both leads of the voltmeter to each wire for one of the injectors to see what number would come up while cranking and it was also about 7 volts.
By the way, I REALLY appreciate your help!
Old 04-04-2009, 07:23 PM
manicmechanix manicmechanix is offline
OK it sounds like you have a spark problem or really a system voltage problem. I don't think 6.5-7V is normal. I think you should see over 9.5V when the engine's cranking.
Old 04-04-2009, 07:58 PM
It may be low because I was jumping it from another car. I'm going to get a battery charger and give it a full charge and try again.
Old 04-04-2009, 09:38 PM
MT-2500's Avatar
AF - Advisor
You need a noid light to check for injector pulse.
Or watch for injector pul;se on a good engine scannner.
If it is getting spark and fuel it should fire.
Pull spark plug and see if any wet or dry on end.
MT
Old 04-04-2009, 11:59 PM
Josh Smith's Avatar
Josh Smith Josh Smith is offline
Send a message via Yahoo to Josh Smith
+1 on the noid light, though I kinda' think the fuel pressure regulator will end up being your problem. That, or a stuck open EGR valve.
I'll also bet your spark plugs will be dry.
Sounds like a lean condition as you've not mentioned gasoline smell.
Josh <><
1993 Olds Bravada, tow package, power everything and leather seats. Currently in restoration. - RIP. Your engine and drive train were excellent, but in the end, too much rust.
2000 Blazer, loaded, looks showroom new, bought April 4th, 2009
Old 04-05-2009, 09:32 PM
Josh <><
My plugs are dry. I took off the EGR valve to take a look at it and that plunger is in the right place and I can push it in and it will spring back. I'm assuming that means it is alright. Is there any way to diagnose the fuel pressure regulator?
Old 04-05-2009, 09:41 PM
Josh Smith's Avatar
What is your fuel pressure at the injectors, or after the regulator? I can't remember how the shrader valve is set up on that one.
What is your fuel pressure, same location, while cranking?
What happens if you turn the key on, off, on, off, on, start? (This is priming the pump).
Right now I'm thinking priming circuit or injector circuit.
Did you try the noid light?
Josh <><
Old 04-05-2009, 09:57 PM
You could pinch off the return line and see if that helps. Earlier you said you put gas in the throttle body and it still wouldn't fire up. That would indicate you weren't getting good spark and maybe because your battery voltage is too low. If the voltage is below about 9Vs the PCM won't cycle the injector. This serves as a safety feature for the engine and cat.
Old 04-06-2009, 08:12 AM
MT-2500's Avatar
AF - Advisor
Recheck for good hot blue spark to all spark plugs.
Make sur engine is cranking good.
Remember 97 is a bad year on ign switches.
Double check all 12 volt ign on voltages.
Does security light work right?
Any aftermarket anit theft or remote stat stuff?
A quick test for fuel delivery problem is to give it a shot of carb cleaner while cranking.
If it fires up with carb cleaner you have a fuel delivery problem.
For fuel pressure check you will need a fuel pressure gauge.
The only true test on a fuel pump is to check the direct fuel pressure from fuel pump.
A quick test is to block off the return line and see if fuel pressure comes up to 75-85 lbs.
But do not run the pump at full pressure very long.
Also when testing fuel pump and pressure you need to tape a gauge to outside windshield or outside mirror and drive it on the road for 20 -30 minutes
until the pump gets has run a while to check for a pump fading out after hot.
Hard to start cold or hot and fuel pressure testing guide lines.
Check cold start fuel pressure.
Check engine running fuel pressure.
Check engine running on the road fuel pressure.
Then shut it off and watch for fast leak down.
Pinch off at rubber part or block off return line and check full pressure.
If pump has full pressure with return line blocked and low pressure without it blocked most usually the fuel pressure regulator is leaking or not holding pressure.
Later V6 and V8 gm engines should have 60-66 fuel pressure.
Cold start should be 64-65 lbs of pressure.
If you do not have full fuel pressure on a cold start the injectors will not squirt fuel.
Do not leave home without it.
Engine running should be 60-66 lbs pressure depending on engine load.
Full pressure with return pinched off should be 75-85 or more.
And if it has a fast leak down after shut off you have a leak in system.
Post back fuel pressure readings.
MT
