Old 04-03-2009, 12:39 PM
lazerphreak lazerphreak is offline
Cleaning car parts?!?!?!?!?
I am replacing the head gaskets in my 1986 ford f150. I am now looking for something to clean my parts off before i put them back into comission. I have tried a de greaser, with little to no effect on the buildup, especially in the valleys under the lower intake manifold. I am now lost in a world of chemical names. I've heard to use Acetone, MEK, even gasoline. NAPA has a 5 gallon bucket of solvent they tried to sell me for the job but it was over a hundred dollars. So my question is, what should i use? and if necessary what kind of gloves should i use when handling it? Im cleaning upper and lower intake manifold, 2 heads, and valve covers. Also i need to clean off the block where the heads and intake go.
Last edited by lazerphreak; 04-03-2009 at 12:40 PM. Reason: cleaning, chemical, part, solvent
Old 04-03-2009, 01:06 PM
james68f100 james68f100 is offline
Re: Cleaning car parts?!?!?!?!?
try using oven cleaner
