Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 04-02-2009, 11:08 PM
gatorbite2 gatorbite2 is offline
Alternator Gauge Concern
2000 Gmc Jimmy 4.3 4x4
I have replaced both my Alt and my battery and belt but my gauge still hangs right below the middle line
when i turn my turn signal on the needle moves with the turn signal up and down slightly
and when my car has been running awhile and i shut it off and then back on after a few min it seems the gauge needle takes forever to get back to the center of the gauge
i had the battery and the alt tested both are working fine and i made sure i had the correct alt in my truck
i checked out a buddies and his gauge stays in the middle and never moves when running and after starting his after running for awhile his goes right to the middle fast
any suggestions would be great
Thanks
Old 04-03-2009, 07:29 PM
b1lk1 b1lk1 is offline
Re: Alternator Gauge Concern
My first suggestion is not to care so much what the factory gauges do. They should be considered more of a guideline than the absolute truth. Have the charging system properly tested while the truck is running. As long as you are getting 13.5V or more at idle there is nothing to worry about. My gauge on my 99 Jimmy likes to play games too. It can be below the middle line at idle when in drive and goes lower if I have alot of accessories going. It does jump up when I hit the gas. That is all that matters.
Are you having trouble with the truck not starting? If not, stop replacing parts as they are probably working fine.
PS: Check all your grounds for the engine under the hood as well.
Old 04-04-2009, 11:20 AM
yeah starts fine no problems there
guess it just concerned me how long it took to come up to the 14 mark when its hot outside or the truck has been running awhile is all
if its cold outside everything works great
thanks for the reply
