Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 04-02-2009, 08:06 PM
lovemybadkitty lovemybadkitty is offline
Talking Pleas Help W/p0430 code
I have heard that a MAS can give a 430 code if defective or dirty. I have installed a K&N air filter and have cleaned the MAS with a commercial cleaner from Auto zone. Have changed both the pre and post flow O2s and have checked extensively for exhaust leaks. Can I have a bad MAS?
Old 04-02-2009, 08:44 PM
ctwright ctwright is offline
Re: Pleas Help W/p0430 code
Could be an exhaust leak or a catalytic converter going bad. The MAF sensor does not cause that code it's your oxygen sensor downstream from the catalytic converter.
Old 04-03-2009, 11:34 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
It's probably a vacuum leak past the MAF sensor that it's not detecting and the o2 is reading a constant lean condition.
Old 04-03-2009, 05:57 PM
How do I find this vacuum leak? Can you recommend where I should start looking? The code only comes from the bank 2 side. Is it possible a vacuum leak can only effect the right bank? Thanks for any help.
Old 04-03-2009, 06:03 PM
I doubt it I think you would be having more codes than what you have but I could be wrong.
Old 04-06-2009, 09:05 AM
wrightz28's Avatar
Check all the vacuum lines that attach to that side of the motor at all connections for cung fit and no breakage.
