Go Back   Automotive Forums Car Chat > Toyota > ECHO/Vitz/Yaris
Old 04-02-2009, 04:16 PM
big rich big rich is offline
2000 toyota echo no power
have a lean exhaust good fuel pressure code p0300 & p0171 any help ?
Old 04-02-2009, 06:16 PM
ctwright ctwright is offline
Re: 2000 toyota echo no power
I'm confused. The title says "2000 toyota echo no power".
P0171 means too much oxygen in exhaust and P0300 means multiple missfire which explains the P0171 because of the missfiring.
Here is a site with telling you how to find and solve the problem when you have trouble codes. www.obd-codes.com/P0300
Old 04-11-2009, 11:38 AM
system is lean good fuel pressure, good 02 sensors ,good injectors ????
Old 12-04-2017, 04:30 PM
Shadab Lodhi Shadab Lodhi is offline
Error Code: P0171 Fuel Trim (FT), System too Lean, Bank 1
Possible Causes:
- Intake/exhaust leak.
- Secondary air injection (AIR) system.
- Manifold absolute pressure (MAP) sensor.
- Mass air flow (MAF) sensor.
Fuel pressure/pump.
- Injector(s).
- Evaporation emission (EVAP) canister purge valve.
- Heated oxygen sensor.
EOBD II Error Code: P0300 Random/Multiple Cylinder(s) - Misfire Detected.
Possible Causes:
- Air Intake System leaking.
- Fuel Supply faulty.
- Injector(s) faulty.
- Ignition Cable(s) and/or Spark Plug(s) faulty.
- Ignition coil(s).Exhaust Gas Recirculation (EGR) Valve stuck/open.
- Camshaft Position Sensor faulty.
- Weak cylinder compression.
